Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > 3rd Gen DIY
3rd Gen DIY
DIY: Differential Fluid Change
This is a discussion on DIY: Differential Fluid Change within the 3rd Gen DIY forums, part of the 3rd Gen : 2002 - 2008 category!
Heres a quick tut for changing out your differential fluid. Its not hard at all. So now you dont have ...
Like Tree2Likes
Reply
Old 06-28-2010, 05:58 PM   #1 (permalink)
OlDirtyJohn's Avatar
Ram Year: 2004 Quad Cab 2500 *Sold*
Engine: Hemi 5.7
Send a message via AIM to OlDirtyJohn
Default DIY: Differential Fluid Change
Heres a quick tut for changing out your differential fluid. Its not hard at all. So now you dont have an excuse to not do this at the recommended intervals.
Step #1 Gather proper tools and equipment.
You will need a 3/8" drive socket set, enough diff fluid of the proper weight, an oil pan, bucket, or something to catch the old fluid in, and some sort of heavy duty cleaner or degreaser (i used brake parts cleaner)
you might also need some RTV if you dont have a gasket on your cover.
[imgl]http://i26.photobucket.com/albums/c114/OlDirtyJohn/DSC_0015.jpg[/img]
Step # 2 Place drip pan under Diff, and start removing Bolts
You need to remove the bolts starting from the bottom and work your way up. This will allow the fluid to start draining without making a huge mess.
Step #3 Allow fluid to drain and remove cover
Wait a few minutes with only the top two bolts loosely in place for the rest of the fluid to drain out. Next remove your cover.
Step #4 Clean out pumpkin/cover and inspect Gears and Gasket
Using a clean rag wipe out all the excess fluid from the bottom of the differential. Use this time to inspect your gears for any abnormal wear or chips, or anything out of the ordinary. DONT USE CLEANER INSIDE THE DIFF!! you most likely wont be able to get it all out, and it could prematurely break down the viscosity of your new fluid. Next, inspect your cover gasket if equipped, and clean out the inside of the cover using the cleaner of your choice.
Step #5 Optional Step
If you have been wanting to get a new diff cover, but dont want to spend the money, you can paint the cover with a can of high temp paint and replace the bolts (I used grade 8 bolts, got them from NAPA), the results will surprise you! And it only takes a few minutes.
Step #6 Replace diff cover
Line up your gasket, or apply RTV gasket maker according to the directions on the package, and put your diff cover back on. torque down bolts according to specs. (in my case it was 30 ft/lbs) I also torqued bolts down in a criss cross pattern to avoid warping the cover.
Step #7 Fill Diff with Correct amount of fluid
To take out the fill plug simply use a 3/8" drive socket wrench. Next fill with diff fluid. (my 10.5" rear took 3 quarts) fill until fluid is just below the fill hole. Next replace fill plug, and torque to specs (24 ft/lbs)
Step #8 Stand back, and enjoy the fruits of your labor
Also, check for leaks. Those are bad.
Burla and usaf2006 like this.
Sponsored Ad
Register to remove this ad.
OlDirtyJohn is offline   Reply With Quote
Old 12-16-2010, 12:40 AM   #2 (permalink)
Ram Year: 2002
Engine: 5.9 Magnum
Default
What are the size of the bolts by chance? Is there any difference between the 1500 and the 2500 bolts other than how many you need
korby05 is offline   Reply With Quote
Old 12-16-2010, 07:13 AM   #3 (permalink)
Trupiano's Avatar
Registered User
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2010 Ram 2500 6.7L CTD Crew Cab
Engine: 6.7L CTD
Default
Great job John! Nice write-up!
__________________
Trupiano is offline   Reply With Quote
Old 12-17-2010, 01:24 PM   #4 (permalink)
Engine: Hemi 5.7
Default
are you talking about the head size? or the thread size? i dont recall off hand. all i did was drive to NAPA, take one out, take it in with me, and find a match.
__________________
2000 Honda Inspire (Acura TL) 2.5l v6 auto, right hand drive. tinted, lowered, debadged, basically riced out to the max!
1996 Mitsubishi Delica Space Gear. 4x4 3.0l v6, bull bars front and rear, side steps, full skid plates.
Old 12-17-2010, 05:23 PM   #5 (permalink)
Ram Year: 2002
Engine: 5.9 Magnum
Default
makes sense.. that's what I would have done anyways.. thanks again
Old 03-06-2012, 06:06 PM   #6 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
I know this is an old post but I just changed my rear diff. fluid and the plug on the diff. cover is basically a rubber stopper. It fits pretty snug. Is this normal?
I have an 03 Ram slt 4x4 with the Hemi
Thanks
PJ
p.s.
Still getting around to updating profile.
PJF0455 is offline   Reply With Quote
Old 03-06-2012, 06:14 PM   #7 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Thanks
PJ
p.s.
Old 03-06-2012, 06:34 PM   #8 (permalink)
BlackedOutHemi's Avatar
Ram Year: 2012 & 2012
Engine: 5.7L HEMI & 6.7L Cummins
Default
Yes. It needs to be to keep the oil from splashing out or pouring out.
__________________
BlackedOutHemi is offline   Reply With Quote
Old 03-06-2012, 08:52 PM   #9 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Thanks
So the one in the Pic up top is rubber also?? Cause mine dosn't have the place for the wrench. I just pryed it out with a flat screwdriver. Was under the impression it was a bolt or sorts.
Thanks
PJ
Old 03-06-2012, 09:08 PM   #10 (permalink)
Default
His doesn't seem to be, may be an aftermarket cover. But mine is.
__________________
Reply
Tags
changing fluid, differential, do it yourself fluid, how to change diff fluid
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
