DIY PCV Valve
Iceskyline25
Houston, TX
This is pretty simple DIY but I figure I would make one in case anyone was having trouble finding it or replacing it.
Time: 10-15min
Cost: $6-$15 depending on where you buy it
Tools:
Flat Head Screw Driver
Needle Nose Pliers
Step 1: Remove Air filter box to have better access to the PCV valve
Step 2: remove the hose attached to it by just pulling on it towards the firewall if it's pretty stuck on there you can use the screw driver to loosen it up.
Step 3: push the PCV valve in and turn it counter clock wise. Then pull
Step 4: Repeat all the steps backwards and your done.
Hope this help someone :)
ralaubach
CA
2007 Ram QC
heard i should do this, honestly never knew where it was, so thanks for the post.
jsmith180601
Just ordered a new one so this will be on my to-do list
Sent from my HTC One VX using Tapatalk 2
Hemiram
PA
Is there an interval (mileage or time) that this needs to be done or is it a symptom thing?
hemihustlin
Montreal
To recirculate crankcase vapors. In other words to burn off oil vapors instead of spewing these terrible fumes into the enviroment!
Its good for dirtying up the inside of your intake and throttle body.
Gniccum
If anyone is wondering, for the 2007 Ram with the 4.7L V8, the PCV valve is to the back right of the throttle body on the valve cover. Use a 35mm deep socket to get it off after you've removed the hose.
Egress
Norfolk, Virginia
03 1500 Quad Cab 4x4 SLT
Stock 235hp 4.7L/287 V-8
I believe that I read somewhere on this site that the 2003 4.7 has an internal PCV, not like the one on this 2002. Is that correct? IF it is internal or more difficult to get too than it needs to be, is it still worth inspecting/changing/ or modifying?
tattooed3177
Bensalem , Pa
is this for a 2004 5.7 hemi ?? the pcv valve the sold me at the store looks way different if not do you have a diy for that ??
jwheeler
Washington
That is a 4.7. Your 5.7 has the pcv valve on top of the intake manifold near the throttle body. Twist the old one out and twist the new one in.
ViperOne
Mesquite NV
I read somewhere they should be renewed every 30,000 miles. Only ran across one bad PCV, it was on my sons 2001 Dakota with 4.7 engine with 177,000 miles. Easy way to tell if good or bad is if they rattle its working, no rattle it needs changed.
