AlohaRam
I recently purchased a 2002 QuadCab with the 4.7L V8... The seller thought it needed new Exhaust Manifolds. Turns out that the 2 rear exhaust studs on each exhaust manifold broke, causing the gaskets to blow out.
I don't know much history on this truck, but apparently it was driven thru salt-water.
Prior to this journey into replacing the exhaust gaskets, the engine and transmission oil pans began to leak. They were rusted so badly, I was able to poke a hole in each with a screwdriver. So I replaced both pans with new.
My Exhaust Manifold Journey >>>
The source of exhaust leak...
What I started with...
Accessing the rusted Manifold Bolts...
At last, the 34" clearance needed to roll out the chassis...
Full Access...
Attacking the rusted fasteners...
All 16 bolts out! ...
To be continued...
Full Access...
To be continued...
