Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > 3rd Gen DIY
3rd Gen DIY
How To: Cleaning an idle air control valve.
This is a discussion on How To: Cleaning an idle air control valve. within the 3rd Gen DIY forums, part of the 3rd Gen : 2002 - 2008 category!
Well, my truck was past due for this, so I figured while doing it, I'd snap some pics and make ...
Like Tree5Likes
  • 5 Post By SmokedRam
Reply
Old 03-03-2013, 07:12 PM   #1 (permalink)
SmokedRam's Avatar
Ram Year: 2005
Engine: 4.7
Default How To: Cleaning an idle air control valve.
Well, my truck was past due for this, so I figured while doing it, I'd snap some pics and make a brief how to on it.
First off, some symptoms of a dirty idle air control valve are:
Engine has a rough idle, might even sound like a miss.
Engine want to "hunt" an idle speed.
Engine hard to start, may require pressing the accelerator to get it to crank.
Stalling at idle.
Now onto the good stuff. First thing you want to do when messing with any sensor is take the battery cables off the battery.
Next locate the idle air control valve. It is just below and forward of the throttle position sensor, attached to the throttle body with one T25 torx screw. You can plainly see it in the pic below, plugged into the connector with the red tab on it.
Next, disconnect the connector and use a T25 torx bit to remove the screw. Then it will come out of the throttle body. If its never been removed, it might take a little force to remove it. But be careful, as there are O rings to seal it that you don't want to damage. Here is mine removed, notice how YUKKIE it is.
Now, take some carb and throttle cleaner and spray it to remove all the gunk and carbon off of it. DO NOT insert anything into the valve to clean the inside, as you might push back the plunger and then this easy job becomes a PITA and these things are $67 each at Advance. Here's mine all cleaned up.
Now, don't go throw it on the truck just yet, let it sit and air dry for about 15-20 minutes. Then you can go ahead and reinstall it. By this time, since you disconnected the battery first, your PCM will be reset after you install it. Now you're good to go.
Sponsored Ad
Register to remove this ad.
SmokedRam is offline   Reply With Quote
Old 10-27-2015, 12:11 AM   #2 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Default
Would it be roughly the same steps on a 2010 model?
Truck has recently starting stalling at low speeds and when braking for a roundabout.
Oil light came on just before stalling.
Might be the cause right?
datan556 is offline   Reply With Quote
Old 12-08-2016, 02:52 PM   #3 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
anyone know how the 09+ trucks control idle? They don't have an IAC on the throttle body...
daveray9 is offline   Reply With Quote
Old 12-17-2016, 11:14 AM   #4 (permalink)
Ram Year: 2011
Engine: 5.7 Hemi
Default
Bump.
My 2011 is having the exact same issue and shutting off during a low idle at a stop.
It seems to be more frequent in colder weather as we have had a cold snap recently. -20c or colder lately and it's happen 6 times in 2 weeks
Sent from my SM-G920W8 using Tapatalk
Artnes is offline   Reply With Quote
Old 12-18-2016, 07:18 AM   #5 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
Curious myself for my 2012.
Old 03-21-2017, 08:36 AM   #6 (permalink)
Drv
Ram Year: 2004
Engine: 5.7 hemi
Default
How often should this be done?
Drv is offline   Reply With Quote
Reply
Bookmarks
Tags
iac valve cleaning, idle air control valve
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY PCV Valve Iceskyline25 3rd Gen DIY 13 07-29-2015 04:55 PM
Air Valve under cab RioRyan General Discussions 12 02-24-2013 09:15 PM
EGR Valve Muddytazz Engine & Performance 5 02-24-2012 08:57 AM
Idle Air Control JeffBeck Engine & Performance 5 02-06-2012 10:04 AM
97 2wd 12 valve cmns2500 Member Trucks 6 07-20-2010 12:58 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
