How to tint your tails using rattle cans
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
Ok, many have asked how to do this, so i figured i would show how to tint your tails, ONLY using VHT Nightshades and clearcoat from your local autoparts, and get great results.
now thru this i used no power tools or anything you cannot get locally and cheap from the autoparts, except the VHT nightshades, i ordered off the i-net
this is what i did, im sure plenty have their own methods, but that is them and this is me, :D
ok gather your materials:
1 - can of nightshades
1 - can of clearcoat (duplicolor was at my autozone)
1 - pack of 600 gritt wet-sandpaper
1 - pack of 2000 gritt wet-sandpaper
1 - bottle of a good rubbing compound ( meguiars ultimate compound is what i used)
few - paper towls
1 - rag to polish when done
1 - bucket with water
ALWAYS HAVE THE SANDPAPER WET WHILE SANDING!
ok to start ill show you pix of the products i used:
1st step - Wet sand your lense with the 600 gritt wet-sandpaper, i only use up and down and side to side motion, no swirling, make sure you have the entire lense dull, anything shiny will not grip the paint to well.
2nd step, you will need to wipe down your lens and make sure all residue from sanding is removed and you have a clean surface to paint.
3rd step - spraying the VHT Nightshades, i use thick heavy coats so that it is semi glossy after each coat, I let it sit for a few minutes, inbetween coats, this stuff dries fast so dont worry.
Pix of each coat of paint:
1 Coat
2 Coats
3 Coats
4th step - the clear coat, after about 10 min i started with the duplicolor clear coat, i spray it the same way as i do the paint, thick and heavy.
Pix of Clear Coats:
1 Coat
2 Coats
OK NOW FOR THE HIGH QUALITY PIX
when you are done you will wind up with a semi shiny set of tails, more than likely they will have a moderate amount of orange peel to them. (see pix)
Step 5 - sanding with 2000 gritt sanpaper, after you have let the tails dry in the sun for about an hour, mine were fully dry, so to remove the orangepeel what you do is get your sandpaper and start sanding the clearcoat, be careful not to go thru the clear coat, but while sanding, wipe them clean frequently, so see how your doing, you will notice when you start sanding you will have a bunch of tiny shiny dots with a dull area around them, you are wanting to sand until all the little dots are gone and its perfectly smooth. (see pic)
Step 6 - the final step - Polishing, i find it best to put em on the truck to polish them, now keeping this simple i polished by hand with my polish rag, use a generous amount of compound the more you polish the better your outcome, so dont be shy, after your done polishing, wipe em down with a clean cloth and stand back and admire your work.
Finished Pix:
ramhunter9
P-Star Jeep Wrangler
Very nice how to .. good work . Looks great
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
purdy
AWE Daniel
Banned
looks nice, The decal on the truck is funny too.
Mbarclay
Canton NY
gotta love tinted led tail. I really miss the ones I had on my bee, my next mod forsure!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Everytime I see you post the how to you make it look so easy and always turn out great.
Demon-HeMi
Demon-HeMi
Houston
if you take your time it will come out great, if your having any problems doing it i can give you some extra tips
Demon-HeMi
Demon-HeMi
Houston
here is a set of 07 tails i did one day out of boredom...
adamwilkes14
Do you know how to candy tails or do you just do the dark tinting? I have a buddy that was candying tails, but got so overwhelmed he has to stop taking orders to catch up.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Excellent Idea and write-up. Thanks! I will see if I can get that VHT stuff and give it a go on my Grocery Getter Magnum as I just ordered Black background headlamps and Black Grille for it and in the rear this would do it! and maybe a debadge or replace the chrome emblems with a set of painted black ones. What do you Think guys/gals!
I have since removed the chrome on the bumpers as the car did not come with it.
Demon-HeMi
Demon-HeMi
Houston
what colors are you wanting and on what
Demon-HeMi
Demon-HeMi
Houston
do it
adamwilkes14
OH, I was just inquiring if you knew how to candy them...seems link candying tails hasnt quite caught on over here yet as much as it has in other scenes...basically candying them makes them resemble a red candied apple rather than blacked out lenses.
In the lowrider scene tinted tails became over used...so now candying them is the in thing to do.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
There's a fella that Hurst Collision had paint his - candied.......man, they looked SWEET
Demon-HeMi
Demon-HeMi
Houston
my set on my hemi is done by hurst, he does color lenses done from factory colors, mine are a black pearl at the moment, soon he will redo them to be the same pearl thats on my truck :patriot:
it will virtually look like i dont have tails
4XLGATOR
CTD
Great write-up and excellent work. They look awesome!
scott2488
Olney, IL
Those look great! same tailllights i just got and will have on here in the next hour i hope. Now i have to decide if i tint them or not
