deuceram
i used a unibut drill bit to put the holes through(use a small bit to drill from the front so you know where to drill from the back i drilled the unibit and the bulbs fit right in enough to not stick far out of the emblem threw a bit of silicone around the backside of the bulbs to seal off where the wires ran off and there it is if any further questions shoot me a message thanks
