Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > 3rd Gen DIY
3rd Gen DIY
Please Help Passenger CV Inner Joint
This is a discussion on Please Help Passenger CV Inner Joint within the 3rd Gen DIY forums, part of the 3rd Gen : 2002 - 2008 category!
I just replaced the lower ball joint and upper control on front passenger side. After a few trips to hardware ...
Reply
Old 05-29-2016, 10:14 PM   #1 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default Please Help Passenger CV Inner Joint
I just replaced the lower ball joint and upper control on front passenger side. After a few trips to hardware store this job was pretty simple and would love to answer any questions regarding the project.
One thing I did during the project was completely remove the CV joint (by the way, this is not necessary). I tapped on the inner cv joint and it slid out pretty easily but I did not take a picture before I did that. Huge mistake. Now after everything is put back together I have a small gap between cv joint and front drive shaft (picture).
Can someone comment if this is correct or if it needs to go on further? If so, is there a tool or trick to it? Could someone post a picture of their CV joint?
After I put everything together I went for a test drive and everything seemed to be fine until I engaged 4WD. Then it was VERY stiff and didn't sound right. I removed the other wheel and drive shaft nut to make sure that the small gap on the outer shaft (in the hub) was supposed to be there and seems like that is ok.
After more review, it sounds like the clip in the middle of the splines on the shaft is all that holds the CV joint. I'm pretty confident that has been engaged so perhaps I pulled out the shaft from the differential when removing the CV joint. Does that look/sound possible?
Thank you for your time and experience. Ask any questions regarding the control arm or ball joint.
Sponsored Ad
Register to remove this ad.
iadams is offline   Reply With Quote
Old 11-02-2016, 04:30 PM   #2 (permalink)
JimsRamTruck2012's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Thanks for posting this.
It sounds like you did everything correctly.
My only question is did you grease the CVs?
JimsRamTruck2012 is offline   Reply With Quote
Old 12-02-2016, 11:21 AM   #3 (permalink)
destroyaYO's Avatar
Ram Year: 2004
Engine: 5.7L V8 Hemi
Default
I am about to do this job but lower control arm bushings , sway bar link rebuild and bearings. My old one looks like that and leaking grease everywhere. My research I would just get a new cv half axle you can get a set for about 130$
destroyaYO is offline   Reply With Quote
Old 12-02-2016, 11:23 AM   #4 (permalink)
destroyaYO's Avatar
Ram Year: 2004
Default
Reply
Bookmarks
Tags
cv joint noise, cv joints, drive shaft
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
CV joint Shclarke Exterior 3 08-20-2015 12:01 AM
04 CV Joint Tbushee General Discussions 1 10-01-2014 10:23 PM
Cv Joint?? brandof Tech Info 1 07-27-2013 09:07 PM
Symptoms of a bad u joint?? brandof Engine & Performance 3 07-24-2013 08:06 AM
CV Joint Luke(MI) Tech Info 9 08-02-2011 10:53 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
