Rough idle, shaking on acceleration.
nyfz1man
So recently purchased my 02 Dodge Ram 1500 quad cab and have been experiencing some troubles.. 5.9 motor has 133k on it.
When I go out for a drive it shakes aggressively on acceleration around 1,500 RPMS and typically in over drive. Some have been leading me towards drive shaft but this problem only occurs when accelerating. If I take my foot off the pedal it stops immediately. I have changed spark plugs, spark plug wires, distributor cap,Throttle position sensor, o2 Sensor, Fuel injector cleaner, ran marvels mystery oil thinking it was a sticking valve. Running out of options and looking for some advice. Along with the shaking on acceleration, I am also getting a rough idle from time to time.
The codes that i have received are..
P0138- 02 Sensor Circuit High Voltage
P0307- Cylinder 7 Misfire Detected
P0172- Fuel System Too Rich (Bank 1)
P0132- 02 Sensor Bank 1 Sensor 1
destroyaYO
5.7L V8 Hemi
I would check/ all O2 sensors and possibly replace cats if you have emission regulations
N
nyfz1man
Is it possible to check my o2 sensors with a scan tool prior to replacing them? Having a hard time dropping hundreds on parts that may be perfectly functional.
pajeepman
SE PA
5.9 magnum
Any idea on what part # you used for front O2 sensor. The one listed for my '03 5.9 1500 has a wire that is wayyyy too short.
Sent from my SM-J320P using Tapatalk
N
nyfz1man
NTK Oxygen Sensor
Part No 23132. Picked it at Advanced Auto and perfect fitment. Heard some rumors that Bosch o2 didn't work well with the Rams so I stayed safe and went with the NTK.
