Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
2001 Alternator
This is a discussion on 2001 Alternator within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
Driving home tonight the volt gauge pegs at 18V. Assuming my alternator effd up I was pulling over to give ...
Reply
Old 09-09-2016, 11:17 PM   #1 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default 2001 Alternator
Driving home tonight the volt gauge pegs at 18V. Assuming my alternator effd up I was pulling over to give it a good smack. Got stopped and it smartened up.
So Im thinking the brushes are bad and thought I had two spare alternators at home. Nope. A 94 and a 99 are different than my 01. Like to make them work if I can.
Anybody know how to rewire my truck.
Where would I find a rebuild kit for my alternator.
(my question marks dont work) (neither do my apostrophes)
Sponsored Ad
Register to remove this ad.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 09-10-2016, 05:22 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
First, try to recreate the problem while a multimeter is attached. Also, check your battery for loose or corroded connections, that can cause high charging voltages as well.
18.6V is very high, i'm surprised nothing was damaged and bulbs aren't burnt out after that, especially given the time it must have been acting up for you to have started to pull over.
Did the lights change intensity? PCM trouble codes (i'm pretty sure too high a charging voltage will throw a code)? What were you reading the voltage off of, factory gauge, aftermarket?
Old 09-10-2016, 08:44 PM   #3 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Didnt act up all day today. Drove maybe 4 hours. Battery is good, etc. Luckily the CHECK GAUGES light came on with a soft bing bing bing of the alarm bell.
Was daytime so I saw no light increase, no codes, factory gauge.
Reman here is $185-$225 plus tax. Used at wrecker is $35 wholesale, $50 retail with 90 day warranty.
Cheap enough to buy a used one
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 10-12-2016, 03:11 PM   #4 (permalink)
Ram Year: 2001
Engine: 5.2
Default
It's a ground.
Had that exact issue.
Cleaned the terminals, cleaned the ground and ran extra ground wires.
One to the alt case itself.
I rebuilt my stock alt and turned the comutator prior to that.
I got the rebuild kit online and I think I searched Denso to find it.
The Commutator was wayout out of wack.
meistermash is offline   Reply With Quote
Old 10-12-2016, 10:01 PM   #5 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Originally Posted by meistermash View Post
It's a ground.
Thanks. I know my ground to the battery is loose. Loose enough to wiggle off anyway. Has been for a year or better. Helps when working on the truck, makes a lazy way of taking it off.
Have yet to have the issue repeat itself. Still same alternator.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 10-13-2016, 12:38 AM   #6 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Yep.
Would only do it every now and then to me.
Old 10-13-2016, 08:08 AM   #7 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
It's one of those things that's going to resurface in a blizzard. Lol.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 11-06-2016, 09:56 PM   #8 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Did it again today. Several times. All I did was shut the engine off and turn the key back on. Engine would fire up and charge fine for another mile. I wasn't even stopping, just going 70mph, shut it off in gear and turn it back on. Tomorrow I'm buying an alt.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 11-07-2016, 09:36 PM   #9 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Got a new to me one for $25 with 120 day warranty.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 11-07-2016, 10:10 PM   #10 (permalink)
Engine: Magnum 360
Default
You did check for corrosion on the battery and alternator terminals right?
If not, there are a couple things that could cause high charging voltages. Make sure you check the voltage sense and excitement wire on the alternator (its a 2 pin connector) If that is loose or corroded, it will cause this problem.
If that is all good, the next cheapest is to replace the alternator. If that doesn't fix it, its possible that the VRM in the PCM is fried.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
200 amp alternator LaurenMagnum360 Audio & Electronics 4 08-14-2016 01:36 PM
Bad alternator Pacheco669 Tech Info 6 04-03-2016 01:07 AM
220 amp alternator jknappen Audio & Electronics 18 05-12-2015 08:21 PM
H.O. Alternator 2012ramHEMI Audio & Electronics 7 03-03-2014 02:25 PM
200 amp alternator G_Altima Audio & Electronics 12 09-27-2013 04:36 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
