Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
2002 ram 1500 oil
This is a discussion on 2002 ram 1500 oil within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
Hey folks , in need of some quick insight. Will 5w50 synthetic oil kill my engine ? It's a 4.7 ...
Reply
Old 09-02-2016, 12:14 AM   #1 (permalink)
Ram Year: 2002 ram 1500 gas
Engine: 4.7
Default 2002 ram 1500 oil
Hey folks , in need of some quick insight. Will 5w50 synthetic oil kill my engine ? It's a 4.7 litre also .
Sponsored Ad
Register to remove this ad.
jordanclpace is offline   Reply With Quote
Old 09-02-2016, 10:40 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Shouldn't but I personally wouldn't go higher than 5w40. Also 4.7 is a 3rd gen engine so those guys would probably know more.
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 09-02-2016, 10:48 AM   #3 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
When looking at multiweight oil, the first number is the weight when the oil is cold, the second when hot.
5 weight oil is thinner than 10 weight oil. In the cold, oil becomes more viscous, so a lighter weight oil is better in the winter when its going to be thicker due to the cold.
The first number is a bit low imo for use in vehicles that dont really see cold winters. I use 5w-30 but I run my truck in temps down to -10F every winter.
I only run 5w-30 instead of 5w-40 because I don't really see hot temperatures in michigan.
imo, 50 weight oil isnt suitable for vehicles that rarely see very hot weather like georgia or florida.
Synthetic wont hurt a bit, it will make any leaks that might be forming more apparent, as synthetic oil will leak in situations where conventional oil will not. That is NOT because it penetrates more than conventional oil.
I don't know where you live. but i'd be concerned that the oil will be too heavy to properly lubricate in a very cold climate, or too thin to properly lubricate in a very warm climate. You can get away with it if you see a bit of both. I have however run my vehicles down around in florida on 5-w30 just fine for a few weeks.
If you have both hot and cold weather, i'd say its fine to use that oil. You might have a bit lower oil flow to the top of the engine and a variance is oil pressure between cold and hot, but you should be fine.
Old 09-02-2016, 03:46 PM   #4 (permalink)
Engine: 4.7
Default
I did look into it more and feel ill be ok , I'm in Ontario Canada . And right now it's still consistently hot .
Old 09-02-2016, 03:49 PM   #5 (permalink)
Engine: 4.7
Default
Thanks a lot for your input , was a great help cheers .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
? About a 2002 ram 1500 meistermash General Discussion 4 08-19-2014 11:08 AM
2002 Ram 1500 tnctx02 Introduction 15 09-01-2013 02:42 PM
2002 2wd 1500 lift on a 2004 2wd 1500 slt? Big O Lifted 5 01-24-2013 02:30 AM
My 2002 1500 Jcasey10 Member Trucks 18 04-13-2011 03:07 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
