the 20 min tb mod
mumbles84
5.9 magnum
I haven't used my dremel in years don't know where it is these are the toools I used 4 inch grinnder, die grinder with a flapper with a 3m scuff pad for smooth finish. Be very care full if using the four inch grinder it make the job really fast but it can bite hard saftey glasses are must I used some wood to screw to a bench so I could use both hand after nocking the horns and silncer down I took the flaper wheel widen the bore then used the scruff pad on the die grinder to smooth every thing soaked it down with some cleaner and blew it off won't know the power for accouple weeks doing some major repairs to truck right now is the intake then the torq convertor this truck is a rust bucket so its stuburn most of the time
DarrenT
New Brunswick
318 V8
Did you ever get round to any of the other work?
Be interesting to see some pics, and a bit more in depth write up.
DT
