2nd Gen DIY 2nd Gen LED dash light Change DIY
This is a discussion on 2nd Gen LED dash light Change DIY within the 2nd Gen DIY forums, part of the Tech Info category! Register to remove these ads. It's free!
Just put mine in and they barely dim if any...
12-03-2011, 12:03 AM
#11 (permalink)
Ram Year: 2001
Engine: 5.2 V8
__________________
Dodge Ram Forum | Ram Forum | Ram 1500 Forum | Dodge Truck Forum | Dodge Ram Parts | Dodge Ram Accessories | Dodge Ram Performance
12-03-2011, 02:25 AM
#12 (permalink)
Site Administrator
Ram Year: 2001 Off Road
Engine: 5.9L V8 Sport
Yeah no dimming. I have read somewhere about something you can add but for me its not that bad at all.
If you do red ones, its is much easier on your eyes too.
__________________
RamForum.com Administrator
Superchips 3715;3rd gen 20s; Cat back exhaust, no muffler;Custom Grill Insert; SRT Hood; Hummer Nerf Bars (PD);Roll Bar (PD); Halo Projectors w/ 6K HIDs; Tow Mirrors; Body matched antennae base and handles; Custom tail Stripe; Custom decals; Painted frame, suspension parts, and wheel wells; Air Horn; Aluminum fuel door; one of kind dents and scratches; 2.5" TGC Leveling Kit; Bilstein 5100 Shocks; LED dash lights ;Cleared needles; blue switches; Painted dash pieces; Pioneer CD player; Cerwin Vega 6x9s , Alpine 5 1/4;Kenwood amp; Boss sub w/Boss Amp; 5% window tint on the back, and strip on the front;[/COLOR]
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
12-03-2011, 09:38 PM
#13 (permalink)
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Yeah, thanks. Old like to do red it orange (like my BMW) the blues look great, but I can imagine my 43 ye old eyes trying to not catch a glare.
per Tapatalk on my EVO
__________________
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
02-17-2012, 05:23 PM
#14 (permalink)
Ram Year: 1998
Engine: 5.9
Do you know what part is needed to get the dimming working again? I am very critical and its bothering me lol.
btw thanks for the right up. I ended up using different LEDs because the light wasnt even throughout the bezel. no need to yank out the metal pieces. all you have to do is remove the old twist locks and bulbs and put these in!
WLED-xHP5-PC: LED T10 Wedge Base Bulb w/ Twist Lock Socket @superbrightleds
02-17-2012, 05:40 PM
#15 (permalink)
Ram Year: 1998
Engine: Magnum 5.2
awessssommeeee! I'm about to order some stuff from them...mind as well throw those in the cart!
Tapatalk Addict
__________________
College rocks, what it does to the mod budget is not.
Mod Thread-http://www.ramforum.com/f17/codes-mod-thread-15049/
02-17-2012, 06:04 PM
#16 (permalink)
Site Administrator
I don't know how to get them to dim. In my research I don't think its possible
__________________
03-07-2012, 02:31 PM
#17 (permalink)
Ram Year: 1998
Engine: 5.9
Well I decided that the window switches needed to be done too. heres a pic of what it looks like done. I didnt take pictures of the process but its pretty straight forward.
tools needed
needlenose pliers
soldering iron
solder
3mm LEDs Link
some type of soldering remover
-remove the switch from the door.
-carefully remove the white bottom cover with a flathead.
-locate the 3 bulbs on the drivers side and 2 on the passengers.
-get some desoldering wick and remove as much solder as you can from the bulbs.
-you might have to wiggle the wires loose.
-I ended up taking needlenose pliers and pulling lightly as I heated up the solder to free them.
-go to ur truck, plug the switch back in (no need to put it all back together) and touch the -leds on each side of the hole to find out what direction they go in.
-then just slide the leds all the way through the hole and solder in. make sure not to use to much solder as the connections might touch each other.
-make sure to test one more time before you but the wires down and put back together
03-07-2012, 02:39 PM
#18 (permalink)
Ram Year: 2001
solder-suckers ftw
__________________
03-07-2012, 03:18 PM
#19 (permalink)
Site Administrator
thats cool. Wish I were good at soldering
__________________
03-07-2012, 05:42 PM
#20 (permalink)
Ram Year: 1998
Engine: Magnum 5.2
thats cooool, damn I need to get to doing this.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
