318 plenum reinforcement kit
lilfroger
5.9 CTD
Install Vehicle: 99 Dodge Ram 1500 318 **same engine used in Dakota's, Ram vans, Durango, Grand Cherokee**
Reason for install: vehicle was loosing oil but no visible oil leak was found, vehicle had jumpy idle, vehicle had sluggish throttle response
Dodge TSB 09-05-00 was issues for this problem; but they just install the same plenum intake plate so it will happen again.
Kit ordered: Hughes Engine V8 INTAKE GASKET HUG 3226 and Hughes Engine PLENUM REINFORCEMENT KIT HUG 7712 from Hughes Engines Kit comes with new intake bolts & bolts for plate.
Other Parts purchased for install: 185 thermostat and coolant intake by-pass hose (hose tends to leak if re-installed so installing a fresh one is just better)
Tools needed: full set of metric and standard wrenches and sockets; make sure you have extensions (you'll need em), INCH POUND TORQUE WRENCH, blue lock tight, black RTV
The 318 before we started:
Disconnect battery & remove coolant overflow bottle
Remove ail filter, plenum and intake tube
Disconnect throttle cable bracket at throttle body
Remove four (4) fan blade bolts push fan back towards water pump. This is to gain clearance for fan shroud removal.
Remove windshield washer fluid bottle from shroud. Remember there are two (2) table inside shroud that need to be released to pull bottle upwards.
Slide fan shroud upwards then out. This is to give room to stand in engine compartment to make to easier.
Remove belt
Remove alternator leads and alternator
Remove ac support, brackets and bolts
Remove IAC, Map, and throttle position sensor connectors
Remove throttle body, gasket, and four (4) bolts
Remove AC compressor connectors (2) Remove AC compressor and swing to passenger side fender (4 bolts)
Remove cross bracket (support for ac lines & air box)
Remove Injector connectors (8)
Remove heater core coolant supply hose
Drain coolant: drain plug turns 1/4 turn clockwise then turn and pull out
Bleed fuel rail pressure with shrader valve then remove fuel rail with Injectors intact
(tie the rail out of the way)
Remove all wiring and associated line, plug wires and upper radiator hose
Remove coolant bypass hose (a new one will be installed on re-assembly)
Plug injector holes to stop debris from getting into cylinders
**Clean all dirt & debris from crevices: if not it will fall into engine**
Remove all intake bolts & remove intake
Place rag or towel on top of valley to prevent gasket debris from falling into valley. Remove all old gasket material.
Place intake on clean surface
-notice the oil vapor stains from vacuum leak in intake
Remove fifteen (15) bolts and lower plate
-note the oil that was pooling inside the intake
Clean intake toughly inside and out: don't use a wookie or scotch-bright: you will get high/low spots and intake will leak
Install new intake plate per instructions in kit. **Note torque specks are INCH pounds not foot pounds**
torque to 48 inch pounds
torque to 84 inch pounds
Install new intake gaskets: use black RTV on lower corners where they cross
Reinstall intake
torque bolts 1 through 4 to 72 inch pounds 12 inch pounds at a time
torque bolts 5 through 12 to 72 inch pounds 12 inch pounds at a time
torque all bolts to 72 inch pounds
torque all bolts in sequence to 12 foot pounds
Once fully torqued begin re-installing all removed components
Add coolant and check oil levels
L
lilfroger
5.9 CTD
Thank you...really common issue w/ ever 318. Dodge's fix was to install the same plate and retard the timing smiley_emoticons_ahhh.gif
The Hughes kit is top freaking notch. Their customer service is great. Buddy of mine got a plate that had at some point taken a tumble and got a few good scratches in it. He called them and they sent him a replacement out that night. He still had the parts by the weekend to do the install.
Any company that makes a great product and has great service is top notch in my book.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Awesome Writeup! Good deal. Love seein this DIY Section Grow. I have done the plate replacement myself.
AWE Daniel
Banned
Is it really worth your time to register all these accounts just to see them get banned with 1 click? Go be a **** somewhere else.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
This is a very common problem but it's not only the 318/5.2, this write up can also be used for the 360/5.9 which has the exact same plenum gasket problem. Nice write-up.
Da Bear
Fort Walton Beach FL.
1999 Larami SLT 4x4
palm 041.jpglilfroger- just did my hughes plenum pan swap using your post. Turned out great. pics were a life saver, most taxing part was cleaning up the surfaces for re-install. Have b een getting 9 mpg since I got the truck from my father in law back in 05, figured it was just a gas hog. Started getting the knock during acceleration and looked into it. All the symptoms pointed to a blown gasket. Thanks for your help. will let you know my gains.
bigTRuckdriver
fort worth, tx
5.9 l
how did it turn out
i saw you were getting 9 mpg before the install, did you mpg increase after the install? i think this may be wrong with my truck, im getting about 9 mpg currently
txbass06
NE Texas
5.9 Magnum
Pull the intake hose off the throttle body and crack the blades open. If you see any oil or residue in the intake at all, your plenum gasket is leaking
ramthis9501
Oklahoma
5.2 V8
Did this myself a couple months ago and it's amazing the difference it made in performance. No more sluggish running and alot better throttle response. Maybe got 1-2 more mpgs
V-10 RAM
Lee Vining CA
v-10
Well checked my Jeep 5.9 & now I know why I'm pinging, & having CEL on converter running too cold, why my mileage has dropped into the 15 range from the mid 17 area. The interesting thing is my oil usage is very little. But the intake has a lot of oil residue.
So that has to be fixed pretty soon. I haven't been driving it much because I have four vehicles.
V-10 RAM
Lee Vining CA
v-10
Thanks for the links. Yes a bit cheaper. With shipping & gaskets it comes to $94.33 which it's a big savings but plenty to interest me.
Thanks Again
Hylander
Commiefornia
Thanks for the write up :)
I have a 94 1500 5.9, just replaced my T-Stat today.
I have residue in my intake, so looks like I need to do this repair.
Question:
How long can I continue to drive in this condition ?
Truck Runs fine, passed smog and I get 10-11 mpg in town and 15 hwy.
This is with 33" tires and 4.10 gears.
I probably can't afford to do the repair until after Christmas.
ktm1217
White Mills, PA
5.2L 318ci Magnum
How long does this usually take to do? Im prob gonna have to do it on my Ram in the near future..
ks2007
Tennessee
5.2L Magnum
also depends how much you have to clean. I'm still cleaning mine 2 days later. I'm just replacing everything I can now. Don't wait too long or this will happen. I didn't have any trouble until last week and I wish I knew to check it sooner.
