95 ABS/brake problem
dodge49
MO
Hi everyone,
I just replaced the front calipers on my 95. I bled the brakes and get all fluid, but the pedal just keeps going to the floor. I'm not sure if I have to do something special with the ABS or am I missing something?
Thanks in advance
sbarron
Wasilla, Alaska
Does the pedal firm up when you bleed or soft al the way through? If it doesn't firm up you still have air in the system, are pumping fluid out somewhere, or your master cylinder is shot.
D
dodge49
MO
It's soft all the way through. I'm 99% sure I got all the air out and aren't leaking any fluid, but I'll double check today. I'll look into the master cylinder, too. Thanks for the quick reply!
