Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Brake tube, what is its purpose?
This is a discussion on Brake tube, what is its purpose? within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
What is the purpose of this tube? It is broken on my truck and was leaking water after being moved ...
Reply
Old 02-22-2017, 07:05 AM   #1 (permalink)
glipman's Avatar
Ram Year: 1998
Engine: Magnum 5.9
Default Brake tube, what is its purpose?
What is the purpose of this tube? It is broken on my truck and was leaking water after being moved around
"inspirational quote" - someone
Sponsored Ad
Register to remove this ad.
glipman is offline   Reply With Quote
Old 02-22-2017, 07:32 AM   #2 (permalink)
Ram444's Avatar
Ram Year: 2014
Engine: Cummins 6.7
Default
I could be wrong but it looks like the actual brake line. ????? Check your brake fluid level under the hood.
Ram444 is offline   Reply With Quote
Old 02-22-2017, 07:54 AM   #3 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
That is your brake line that goes from the frame to rear axle. Brake fluid is clear almost like water. You probably don't have any rear brakes, you might also have a burned out brake warning light in the dash.
__________________
I fixed it until it broke.
Old 02-22-2017, 08:53 AM   #4 (permalink)
glipman's Avatar
Ram Year: 1998
Engine: Magnum 5.9
Default
The light works and it has brakes. I followed the line and it's plugged up at the body. It is a rubber hose that runs into the block for the brake lines
Old 02-22-2017, 09:02 AM   #5 (permalink)
jwheeler's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
If you brakes still work, it is likely not a brake hose. Probably axle vent tube. Are you sure that it is number 7 in the pics? And that it doesn't actually go on top of number 8? That is where the vent goes, it is not in those pics
jwheeler is offline   Reply With Quote
Old 02-22-2017, 09:04 AM   #6 (permalink)
jwheeler's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
1 is a brake hose. 2 is the axle vent. Just tie it up where water won't get in.
Old 02-22-2017, 07:29 PM   #7 (permalink)
Engine: Magnum 360
Default
Jwheeler found a good diagram for it.
Part 7 in the first diagram is a brake line. Part 8 is the axle breather that also has a rubber line attached.
If the tube you're talking about is for the axle breather, just zip tie it to the top of the frame rail or something where it wont get caught. If there was a lot of water coming from it (I mean more than a few drops or a quick stream) you'll want to consider removing the differential cover and replacing the differential oil.
__________________
Old 02-22-2017, 07:49 PM   #8 (permalink)
Ram Year: 2011
Engine: 5.7 HEMI
Default
Number 7 comes out of the axle thus must be the axle breather tube.
In any case there should be NO water inside!
You should check your axle gear oil!
Chris
__________________
My worktrucks to haul salty and sand dive gear from the beach
1995 RAM 1500 3.6l single cab 2x4 (rusted away)
1998 Dodge Dakota quadcab 5.2l 4x4 (rusting slowly away)
My 2016 xmas present (self-gifted)
2011 RAM 1500 Sport 5.7l HEMI 35tm (mint)
CostaRam is offline   Reply With Quote
Old 02-22-2017, 09:04 PM   #9 (permalink)
glipman's Avatar
Ram Year: 1998
Engine: Magnum 5.9
Default
Thank you very much! It was the differential breather. Boy there's alot of nastiness in there, a good quarter cup of water came from the pipe alone time.to clean her out and lube it back up
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Longer tube tube for my vararam jonathanhudaon Lifted 5 10-06-2016 09:41 AM
Can anyone tell me the purpose of this ? DRkNESS Engine & Performance 23 05-22-2016 12:26 PM
Trailer brake controller: purpose? / mechanism? TonyMM Garage 2 04-23-2016 08:53 PM
Best all purpose tires?? MarkV Exterior 26 04-15-2015 07:04 AM
long tube vs short tube ? ramhunter9 Engine & Performance 24 07-28-2010 10:36 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
