DIY Upper & Lower Control Arms Replacement
Blademccarty
3.9 V6
So my truck is squeaking and I'm guessing its either ball joints or control arms. I was just wondering if anyone knew how to replace my upper and lower control arms? I've been studying a DIY method for everything on my truck and wanna learn everything about everything in detail. Also inner and outer tie rod installation? And a DIY Method for a sway bar links and pitman arm??
Any and every bit of info helps!
2001 Dodge Ram 1500 Sport 2WD
Regular Cab
