Fatbobs 2 inch spacers 2WD install
LilRamMan
Haslet Texas
I dedicate this thread to the codes himself.... Lol here ya go man hope it helps.
First obviousy loosen the lugs , put it on jacl stands, and take the wheels off.
First I un bolted the two bolts to take off the brake caliper. You'll need a pretty good sized allen wrench.
LilRamMan
LilRamMan
Haslet Texas
Then take out the castle nut on the tie rod end. And the cotter pin first o course.
LilRamMan
LilRamMan
Haslet Texas
Then whack it til it falls apart lol.
LilRamMan
LilRamMan
Haslet Texas
Then un do the sway bar on BOTH sides and twist it up and towards the front if the truck to get it out of your way.
LilRamMan
LilRamMan
Haslet Texas
Oh yea forgot to tell ya, at the beginning, support the lower control arm with a floor jack. And after the brake caliper, take off the upper shock nut and bushing. Then pull down in the shock to pull it out of its litle hole lol and get it out of the way.
LilRamMan
LilRamMan
Haslet Texas
Then I used a coil spring compressor to compress the coil.
LilRamMan
LilRamMan
Haslet Texas
Then I took iff the other castle nut off the upper ball joint. And whacked it til it fell out and I let down the jack to ease pressure off the coil and take it out.
LilRamMan
LilRamMan
Haslet Texas
Sorry in the first pic I had already taken the castle nut off and didnt wanna put it back on just for a pic lol. You get it tho.
LilRamMan
LilRamMan
Haslet Texas
Then I just put the spacer on top of the coil, shoved it back in, and reassembled!
the codes
Houston, Tx
Magnum 5.2
nice! thanks bud I appreciate this lol I'm pretty sure when I do mine I'm gonna print this thread out lol
Tapatalk Addict
the codes
Houston, Tx
Magnum 5.2
did you replace your shocks with longer ones?
Tapatalk Addict
the codes
Houston, Tx
Magnum 5.2
thats why I havnt done mine yet lol have the lift kit but need the shocks lol
DukeCity
Rio Rancho NM
Magnum 5.9
That is what I thought I still need to put my level on... From last summer
VLG6963
