96 ram 1500 4x4 5.2
Just recently gave big red a tune up...
Plugs
Wires
Cap
Rotor
Pick up
Coil
Oil change and filter
Air filter
And after tune up, I noticed that the idle was high (1170 -1200rpm). I read about IAC..., CLEANED port and replaced IAC motor with new one..still high. Replaced MAP sensor and TPS too (nearly 20s old). Idle still high. I then disconnected and plugged all vacuum lines and ports. Idle lowered to 810/850 rpm and purred like a kitten. I then started hooking up vacuum lines one by one to see if idle changed. All was good until I got to the last hose. I removed the plug in the hose going to the crankcase breather on top of the valve cover and voila...Idle went up to where it was before. I'm stumped...hoping someone can offer suggestions.
Plugs
Wires
Cap
Rotor
Pick up
Coil
Air filter
