Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Hub assembly
This is a discussion on Hub assembly within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
While rotating my tires today I found that the driver side hub bearing sounds "not normal" there is no play ...
Reply
Old 10-30-2016, 01:05 AM   #1 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default Hub assembly
While rotating my tires today I found that the driver side hub bearing sounds "not normal" there is no play yet but the passenger side is silent when I spin it.
Seems you have to replace the entire hub assembly.
Is it as straight forward as it looks, are there any hidden bombs I should be aware of?
Sponsored Ad
Register to remove this ad.
Gr8bawana is offline   Reply With Quote
Old 10-30-2016, 08:49 AM   #2 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
It's simple. I wanted to come up with some horror story but it's just to easy to swap.
Just pull the diff, put it on the bench and clamp it down. Then heat the housing red hot with a torch before removing the bolts. You want to boil the grease out of the bearing. Cut the diff housing and stick the hub in a hydraulic press. Press it till the bolts snap. Drill those out and rethread for new bolts. Install new hub and weld everything back together. Spray with WD40 and reinstall in your truck.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 10-30-2016, 01:30 PM   #3 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
It's this one at the wheel.
http://www.ramforum.com/attachment.p...1&d=1477844964
Old 10-30-2016, 02:47 PM   #4 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
Ram Modifications
__________________
BBartow is offline   Reply With Quote
Old 12-21-2016, 08:39 PM   #5 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
Ok guys I'm finally getting around to changing out the hub assembly. After finally getting the 3 mounting bolts to break free using a 3 foot cheater pipe I had to order a 43mm socket for the spindle nut because nobody in my small town had one.
My question is whether the axle shaft is going to be frozen onto the hub assembly and if there is a trick to getting the assembly off the axel?http://www.ramforum.com/attachment.p...1&d=1482367127
Old 12-21-2016, 10:17 PM   #6 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
Its a Dodge invest in 5lb sledges
but getting the unit bearing off the knuckle is the hard part. Cover that bitch in antisieze to save your life when you do ball joints. Axle shaft is usually fine.
__________________
Old 12-24-2016, 12:22 PM   #7 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
Well I finally got it done. I broke 2 half inch ratchets, my tourque wrench and my breaker bar trying to get the castle nut off the stub axel. What a pain in the ass. The two auto parts stores with loan a tool programs did not have any impact wrenches.
A guy next to me heard what I was doing and asked where I lived and then he told me he lived about 3 blocks from me and would be right over with his impact gun.
He came over and zapped the nut off in about 3 seconds. He showed me where to give the axel a good whack to break it free from the hub and not screw up the threads, he knew how to get the hub off the knuckle pretty easily. We put the new hub assembly on and he tourqed it down all in about 20 minutes.
He was a complete stranger to me yet he took time out of his day to help me out. In thanks my wife sent a big box of freshly baked xmas cookies and I gave him a big hunk of elk salami which really thrilled him.
While talking to him I found out he grew up on a farm in Iowa and had been in the military with 3 tours to Iraq and suffers from PTSD. I thanked him for his service and for bailing my butt out.
It restores my faith in my fellow man to have an experience like that.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
04 Hitch Assembly Kapt Towing & Hauling 2 12-30-2015 09:24 PM
Hub assembly Essayons_01 Lifted 8 06-01-2015 12:59 PM
hub assembly? night hawk Tech Info 3 08-08-2013 02:53 PM
Front Hub assembly Browns111 Tech Info 1 08-04-2013 02:41 AM
2nd gen foglight assembly onebadbee For Sale 3 03-11-2011 11:16 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
