Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Leaking steel brake line
This is a discussion on Leaking steel brake line within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
you shouldn't need to bleed the master cylinder unless you run it dry so make sure to top it up ...
Reply
Old 01-03-2017, 11:53 AM   #11 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
you shouldn't need to bleed the master cylinder unless you run it dry so make sure to top it up or check it before starting. if you hook up the line to the abs thing first the line might bleed itself by the time you go to hook up the other end. you can sometimes get away with bleeding it like that but if it don't work you would then just have to bleed it at the caliper
Sponsored Ad
Register to remove this ad.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 01-03-2017, 01:41 PM   #12 (permalink)
Ram Year: 1998
Engine: 5.2
Default
Any tips for bending brake lines? Never done it before. Not sure what I should or shouldn't do. Any advice would be great.
jackson4212 is offline   Reply With Quote
Old 01-03-2017, 03:04 PM   #13 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
YouTube it, chrisfix has a good video on it
12vcummins59 is offline   Reply With Quote
Old 01-03-2017, 03:12 PM   #14 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
a cheap tubing bender works good for tight turns if you need to bend any but for the most part you should be able to bend light bends by hand.
__________________
Old 01-03-2017, 04:14 PM   #15 (permalink)
Ram Year: 1996
Engine: Cummins 12V 5.9L
Default
I bled all my old fluid out it was trash I just used a like a foot of clear tube that fits over the nipped and in to a jug so it can't suck air back in
Sent from my SAMSUNG-SM-G890A using Tapatalk
tactialmonkey is offline   Reply With Quote
Old 01-04-2017, 12:12 PM   #16 (permalink)
Ram Year: 1998
Engine: 5.2
Default
I got the job done, thanks for the help guys
Old 02-01-2017, 08:55 AM   #17 (permalink)
Ram Year: 1995
Engine: 5.2 magnum
Default
I had a leak under the cab and many other questionable lines. I took the easy way out and went pre bent from sstubes. $200 did the whole truck, but they break it up into 3 or 4 sections depending on what you want to work on.
Edit, didnt see second page you got er done. Lol
Blain is offline   Reply With Quote
Reply
Bookmarks
Tags
brake line, brakes, steel
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission Line Quick Disconnect Leaking?? hemimike04 General Discussions 1 04-28-2016 01:56 PM
ABS and Brake light on after replacing brake line 94dram General Discussions 1 09-13-2015 09:08 AM
Transmission Fluid Line Leaking Magnum5.9 General Discussion 13 01-21-2015 09:49 PM
Ram 2500/3500 03-09 Rear Stainless steel braided brake line - 6 inch lift AlljackedupRam For Sale 1 03-16-2014 08:52 PM
Brake line help.... also I think my t case is leaking. 2ndgenramman Tech Info 2 07-27-2013 10:16 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
