Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
P0308 Misfire? Could've been a valve cover oil leak.
This is a discussion on P0308 Misfire? Could've been a valve cover oil leak. within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
So, ever since december my truck began to misfire. Specifically the 8th cylinder. Looking at a bunch of things online, ...
Like Tree3Likes
  • 2 Post By dodge dude94
  • 1 Post By dapepper9
Reply
Old 02-15-2017, 09:51 AM   #1 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Engine: 5.9 Magnum V8
Default P0308 Misfire? Could've been a valve cover oil leak.
So, ever since december my truck began to misfire. Specifically the 8th cylinder. Looking at a bunch of things online, I arrived to the conclusion that it must be the plenum. Boy was I wrong.
While I was saving up money to get a plenum repair kit, I decided it was about time to change my spark plugs and finally fix the valve cover gasket leaks that were going on. Well, upon removing the 8th cylinder spark plug, this is what I found:
It's entirely caked in oil. No wonder it was misfiring!
So, after replacing it with Champions, it ran just like the day I bought it.
The moral of the story is to always keep your valve covers from leaking.
Sponsored Ad
Register to remove this ad.
__________________
http://i987.photobucket.com/albums/ae356/wwiiiprod/yeeyee_zpswapzodeh.jpg
Jegs Off Road Y-Pipe, Stant 180 Deg. Thermostat, Mota 14x2 Air Cleaner, Spectre Breather Filter, MSD Blaster Ignition Coil, BWD Distributor and Rotor, Champion Spark Plugs, B&W Gooseneck Hitch, 245/75/16 Cooper Mudclaw
bluwarguy is offline   Reply With Quote
Old 02-15-2017, 10:20 AM   #2 (permalink)
MCIntoDarkness's Avatar
Ram Year: 1998
Engine: 3.9L Magnum V6
Default
This has got me thinking that this might be the cause of my misfire on cylinder 6 on my 3.9L. I always get it if I push the truck about 70-75mph.
__________________
---My Truck---
1998 Dodge Ram 1500
Bright White w/Grey Interior
3.9L Magnum V6 w/Auto Transmission
Check Out My Build Thread!
The Green Hornet
MCIntoDarkness is offline   Reply With Quote
Old 02-15-2017, 01:22 PM   #3 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Default
mine was always around 45mph and above
turning overdrive off helped it stop, but I figured out the permanent solution thank god
__________________
Old 02-15-2017, 10:32 PM   #4 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
A leaky valve cover won't cause that fouling, that's a bad plug or excessive oil dump from the valves.
Yeret and Rlaf75 like this.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 02-16-2017, 03:05 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
^^^valve cover leak can't get into the cylinders
Yeret likes this.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 02-16-2017, 03:23 PM   #6 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
If it was a valve cover leak there would be nasty oil residue all over the outside of the plug. Oil can't seep into the cylinder.
Gr8bawana is offline   Reply With Quote
Old 02-17-2017, 12:43 AM   #7 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
If it did, you have worse problems than a miss at certain speeds
__________________
I fixed it until it broke.
Old 02-18-2017, 01:35 PM   #8 (permalink)
Yeret's Avatar
Location: Under the hood, trying to find that ****ing bolt
Ram Year: 1999
Engine: 5.9 Magnum
Default
Wow, that is probably the worst fouling that I've ever seen on a spark plug. Even when my plenum was leaking, my #8 plug wouldn't foul that bad.
Pepper's right. Leaky valve covers at worst will coat the outside of the spark plug, but a leak there won't find it's way into the cylinders unless maybe the intake manifold gaskets are also toast.
If you're using oil, knowing that it's a Magnum engine, I'd plan on doing the plenum repair. If money's tight, people have had success with simply using a revised Fel-Pro plenum gasket for 20 odd bucks rather than shelling out the 160 for the kit.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, canned 91 tune by Flyin' Ryan, Hughes plenum repair, steering stabilizer, 4x4 Posi-Lok, on-board Money Sink 3000
Yeret is offline   Reply With Quote
Old 02-21-2017, 11:48 PM   #9 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
Plenum plate would be my guess as well. I recently bought a 96 off my niece which I know needs the fix. No vacuum, misfire on #8, oil consumption and leak down the back of the block, as well as if I let it idle long enough the miss gets slightly worse.
Shadow_Death is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Weekend tune up possible leak on valve cover. Steamer170 Engine & Performance 7 01-11-2017 12:40 AM
valve stem leak??? and plenum leak?? wmkfisher Engine & Performance 1 07-30-2016 09:32 AM
Cylinder 8 misfire - burned valve? 05ram4x4 Engine & Performance 48 05-30-2016 08:59 PM
Valve covers cuz oil leak Roadkill Engine & Performance 7 07-06-2015 09:14 PM
Under valve cover pic.... pressurepro Engine & Performance 5 04-28-2015 08:06 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
