Question on 2000 dodge ram 1500
boilermakerferre
Hi guys I'm new on here , I have a question , hoping someone out there can help . I have a 2000 ram 1500 with 360 , about 80 percent of the time my truck won't start right up . U can hear the starter clicking but won't engage until after several attempts ... Iv checked all the wiring for the relay and starter connections ,all that is Good .. even replaced the starter . when I checked the relay I found that someone has taken it out and replaced it with a jumper wire . I put a relay in it and it won't do anything at all . So I had to put the jumper wire back in it ... if u even might know what to try I'll give it a shot and see if it work ... ?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Merc225hp
NA
truck
gas
Welcome to Rf.
You might check out the n safety switch on the tranny see what's going on there.
B
boilermakerferre
Ok , I'll check it out , thank u ..
