Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Rear differential noise
This is a discussion on Rear differential noise within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
There is a lot of clunking noise coming from the back of my truck. I suspect it is the rear ...
Reply
Old 01-23-2017, 02:46 AM   #1 (permalink)
Ram Year: 1998
Engine: 5.2
Default Rear differential noise
There is a lot of clunking noise coming from the back of my truck. I suspect it is the rear differential.the breather hose was dragging when I bought it. I suspect water got inside and messed some stuff up. Do you suspect it can be fix or would I need to replace the whole thing. Also, how long do I have to fix before it stops working from when the noise started.
Would a repair kit with suffice, do they sell gears to replace, or would the whole unit have to go?
1998 doge ram 1500 5.2 Laramie
Sponsored Ad
Register to remove this ad.
jackson4212 is offline   Reply With Quote
Old 01-23-2017, 12:48 PM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
You'll have to pull the cover to answer any one of those questions really. If you have stuff floating around in there it could last a day it could last a year.
They do sell rebuild kits with new bearings and deals and everything but unless you've done a differential before or are very mechanically inclined and can afford to have the truck done for a few days to a week or more, take it to somebody else or swap in a whole good rear. Differentials are very detail oriented and meticulous.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-23-2017, 03:04 PM   #3 (permalink)
Ram Year: 1998
Engine: 5.2
Default
I was looking on RockAuto.com and there appears to by different differentials for my truck. How do I determine which one to get?
Old 01-23-2017, 04:26 PM   #4 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
The Dana 44s are for the front differential if you have 4wd. Since this is the rear differential, you will need to use the 9.25", if you just want a direct swap. I'm not sure if you can stick a Dana 44 on there with a higher ratio.
Old Yesterday, 06:13 PM   #5 (permalink)
Ram Year: 1996
Engine: 5.9l v8
Default
Hey just lookin for some advice i have a 96 ram 1500 5.9l with a 9.25 rear end and im in the middle of changing both pinion bearings and seal and i noticed there is some damage to the gears on the pinion and im not going to use it anymore of course but i have a 01 durango with the 12 bolt 9.25 rear end in it aswell not sure if same gear ratio yet but if it is can the pinion out of the 01 durango be swapped into my ram 1500 any advice or tips would be helpful and to just say yes i know just buying the ring and pinion kit would be the best way to go and easiest but dont really have the funds for the kit cuz i didnt expect to run into this prob with the pinion being damaged so there is that haha
Bretata96ram is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rear Differential Grinding Noise On Take Off rambodood Engine & Performance 6 02-05-2015 10:00 PM
Rear Differential Fluid tdowhan55 Engine & Performance 16 11-03-2014 12:32 PM
'04 Ram 1500 Rear Differential GreenClassic Wanted 0 07-17-2014 01:20 AM
help with rear differential matt1881 Tech Info 6 07-04-2013 03:13 PM
rear differential help! Hoots Engine & Performance 4 03-21-2013 06:29 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
