Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Round Air Filter
This is a discussion on Round Air Filter within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
So, I'm thinking about buying a round air filter for my 97 Ram: https://www.amazon.com/gp/product/B0...A30XU5Y510T9EB I already know I need to ...
Reply
Old 11-11-2016, 10:31 AM   #1 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Engine: 5.9 Magnum V8
Default Round Air Filter
I already know I need to fabricate an S-Bolt so it fits on the tb, but is there anything else I'll need? I've read online about replacing the PCV with a breather filter, but other than that is there really anything else I need to do?
Sponsored Ad
Register to remove this ad.
__________________
Straight Piped
Stant 180 Deg. Thermostat
Spectre Throttle Body Spacer
Mota 14x3 Air Cleaner
bluwarguy is offline   Reply With Quote
Old 11-12-2016, 02:50 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
They sell kits to add small round filters to the pcv hose.
as for anything else, you just have to make sure it doesnt fall off the TB
Old 11-19-2016, 03:13 PM   #3 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Nope. The edelbrock 10x2 round element from any parts store works pretty plug and play with a spectre s bolt (also found at these parts stores). 14x3 however is the only way to get one with a cotton filter instead of paper and requires a drop base. Spectre bolt works fine still, k&n kit cam be found at autozone that's pretty plug and play with the bolt. Many have a spot for the pcv hose as well
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 11-19-2016, 08:53 PM   #4 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
If you use a drop base you'll need spacers
__________________
BBartow is offline   Reply With Quote
Old 11-22-2016, 01:09 PM   #5 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
Why would you want your truck breathing in hot air from under the hood? There is a good reason these trucks have a snorkle to bring cooler air in from outside the underhood area.
Gr8bawana is offline   Reply With Quote
Old 11-22-2016, 01:39 PM   #6 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
You don't really believe that crap do you? You won't notice any difference between the 2 especially with the iat heat soaking in the manifold
Old 11-22-2016, 02:26 PM   #7 (permalink)
Engine: Magnum 318
Default
It won't really make a noticeable difference drawing from either. Unless you block the whole radiator with cardboard like I did.
With the cardboard in place, my coolant stays at a nice 200-210. the IAT was reading 65*F the other day fully warmed up after a 20 mile drive, and sitting in a parking lot running for about 5 minutes. I'm sure it would be a bit higher without the snorkel, maybe by 20-30*F. But it was bloody 12*F outside.
Perhaps you could notice a difference if you moved the IAT sensor. My truck was definitely more peppy even with the winter blend fuel than it is in the summer when the IAT sensor reads 150*F+.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
round two THETANK General Discussions 24 06-12-2016 08:33 PM
Cabin filter hole open from factory but not filter. Totesmygoats General Discussions 12 05-28-2016 10:13 PM
Buying filter/gasket for 46RE trans - Felt filter? Lethalweapon100 General Discussion 4 11-10-2014 08:55 PM
Round 2!!!! Bigtman07 Photoshop 88 12-27-2010 10:28 AM
Round 2 Startup!!! Bigtman07 Photoshop 55 12-19-2010 01:39 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
