Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Second fuel tank
This is a discussion on Second fuel tank within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
Iv'e a thought. I do not run a spare tire in the back carrier. Mainly due to it wasn't there ...
Like Tree3Likes
  • 1 Post By dapepper9
  • 1 Post By Jimmy68
  • 1 Post By Jimmy68
Reply
Old 10-29-2016, 10:19 AM   #1 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default Second fuel tank
Iv'e a thought. I do not run a spare tire in the back carrier. Mainly due to it wasn't there when I bought the truck and the dual exhaust is now in the way.
My exhaust system need to be replaced now as it's old and broken.
So... I can use that space for a fuel tank. Building a fuel tank is simple but I just got to thinking about it and how would you pump the fuel?
I'm thinking another stock pump connected in line with the original. Add one way check valves if needed.
Now if I power each pump off a two way toggle switch I can turn on one or the other as needed.
Simple. Fill both tanks. Switch on secondary and run till dry then flip the switch to main and continue on with the benefit of having a gauge till it's time to fill again.
Any ideas?
Sponsored Ad
Register to remove this ad.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 10-29-2016, 10:55 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
That would work. Would be like the old Fords with dual tanks. Would need mount flanges to bolt it up and filler hose might be tricky
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
dapepper9 is online now   Reply With Quote
Old 10-29-2016, 10:56 AM   #3 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
Dude....DO IT!
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 10-29-2016, 11:02 AM   #4 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
If you get something nice and clean set up that could be something a lot of people would be interested in
dodge dude94 likes this.
__________________
Old 10-29-2016, 12:02 PM   #5 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
I have a flat deck on my truck and all the hoses and tubes can be got at work. I'll probably just come out the side. Over the frame and mounted to the bottom side of the deck for the filler or make a fuel door in my deck floor.
Making mounts would be easy enough and I'd maybe tab it for a bolt on tank or maybe I could use undersling straps.
Be nice if I come up with a simple bolt on kit using factory holes.
Looks like a 28"x24"x12" tank will fit. netting me a 29 US Gallon tank. Basically doubling the fuel capacity of my 26 Gal I now have.
If I had a 35 gal factory tank plus the 29 Gal, that would be cool.
All this will fit between the frame and between the hitch and diff. Also at 12" deep it still is protected from the rear by the hitch and bumper as it will not hang lower than the hitch.
With closer measuring I may get a 29x29x12 which nets a 36.3 Gal tank. But that leaves little room around it. Be tight. But doable.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 10-29-2016, 12:06 PM   #6 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Originally Posted by dodge dude94 View Post
Dude....DO IT!
Old 10-29-2016, 10:01 PM   #7 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
You can even get switches for this, they pass through the sending unit information for the selected tank. You could also get a round fuel gauge to mount in the pillar gauge trim pieces, that would be pretty cool.
I say do it, just make sure to add a skid plate for the tank.
Old 10-30-2016, 07:59 AM   #8 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Skid plate maybe. Depends on what I build it out of. If I use 20 gauge and a 1/8" skid plate. I could probably just use a 1/8" bottom on the tank. A skid plate would be simple though and add protection from debris.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fuel tank help!!! Miken1213 General Discussion 7 04-05-2016 06:04 PM
How much fuel can you get in your tank? zoomzu General Discussion 11 02-13-2016 04:54 PM
small fuel leak at fuel tank RAtmosphere 5.9 Common Rail 1 02-05-2014 04:22 PM
Fuel tank Marc1982443 Exterior 14 06-20-2013 10:04 AM
Fuel tank Q? srt8dork General Discussions 21 11-19-2010 02:36 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
