Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Sloppy Steering Adjustment
This is a discussion on Sloppy Steering Adjustment within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
Ok I know many 2nd gens out there have this problem. So here is a simple DIY To follow to ...
Like Tree5Likes
Reply
Old 08-18-2010, 11:57 AM   #1 (permalink)
Bigtman07's Avatar
Registered User
Ram Year: 1998/2000
Engine: Magnum 5.9/Cummins 5.9
Send a message via Yahoo to Bigtman07
Post Sloppy Steering Adjustment
Ok I know many 2nd gens out there have this problem. So here is a simple DIY To follow to take care of some of the slop. Maybe correct some wheel angle problems. I will be adding pictures later for better clarification.
Difficulty Rate: If you can turn a wrench you can probably do this.
(This DIY is intended for instructional purposes and I nor the forum are responsible for any damage while you are following this DIY. Use your best judgment while working on your truck. Be safe and follow safety precautions.
In short; you are on your own I am only providing you a guide.)
Tools Needed:
16mm Open End Box Wrench
4.5 or 5.0 hex key.
Maybe some Brake Cleaner for the dirty ones
Step 1:
If the box has dirt and other debris on it you are going to want to spray the box down with brake wash to remove most of the dirt. Make sure you clean the top of the box.
Step 2:
On the top of the steering gearbox you will see a large bolt located on the top near the middle. This is the 16mm bolt that you will need to lossen.
Step 3:
Insert the Hex Key into the top of the nut and point it to wards the front of the truck. Then loosen the 16mm nut about 1 or 2 turns. Keep the hex key pointed to the front.
Step 4:
Either have another person sit in the truck and wiggle the wheel back in forth while you tighten the screw or get up and down a lot to take up the play. You should only adjust the screw about a 1/4 turn at a time. A 3/4 turn will roughly take out 2 inches of slop. Don't tighten the hex too tight or it may cause damage to the steering box. The steering should be tight but not so tight that when you are finished that you have to muscle the wheel.
Step 5:
After adjusting the screw. Hold the hex in the position where you adjusted it and tighten the 16mm nut. Nice and snug. DON'T OVER TIGHTEN.
Step 6:
Start the truck and check for any leaks. Test your steering see if you still have play. If so you can repeat the steps to get rid of most of it.
98blackbeauty likes this.
Sponsored Ad
Register to remove this ad.
__________________
Never Apologize for being Patriotic! 'EM Join Hunter nation! RF Hunt Club!
"If he's gonna put his lips on something I made I'd rather it be a duck call." ~Willie Robertson
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Bigtman07 is offline   Reply With Quote
Old 08-18-2010, 04:23 PM   #2 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
nice DIY ... should come in real handy for the 2nd gen crowd
ramhunter9 is offline   Reply With Quote
Old 08-18-2010, 04:48 PM   #3 (permalink)
Bigtman07's Avatar
Registered User
Ram Year: 1998/2000
Default
I'm hoping. Being a 2nd gen I plan on doing many more writeups. I'll be doing some Video DIY and DIY with pictures. Pictures will come when I get home. Oil Change DIY is next if ya think I should make one up for that.
__________________
Old 10-12-2010, 09:46 PM   #4 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
This also goes for 3rd gen trucks , I have done this and it works !
Old 10-22-2010, 05:09 PM   #5 (permalink)
Ram Year: 1999
Engine: 5.2
Default Please clarify
I haven't seen anyone mention it but when you are wiggling the steering wheel I assume the engine is off so that the power steering isn't being used.
Billyg is offline   Reply With Quote
Old 10-22-2010, 05:10 PM   #6 (permalink)
Bigtman07's Avatar
Registered User
Ram Year: 1998/2000
Default
Yup that is correct. If you start the engine while doing this you will get a shower of PS Fluid. (Knows from experience) lol
__________________
Old 10-22-2010, 06:45 PM   #7 (permalink)
Ram Year: 1999
Engine: 5.2
Default
Thanks!
Old 10-22-2010, 07:30 PM   #8 (permalink)
Bigtman07's Avatar
Registered User
Ram Year: 1998/2000
Default
No problem.
__________________
Old 06-21-2011, 10:45 PM   #9 (permalink)
Banned
Ram Year: 1998 Chevy Blazer
Engine: 4.3l Vortec V6
Default
FYI, if you do not have a 16mm, 5/8" SAE is the same size.
Luke(MI) is offline   Reply With Quote
Old 08-04-2011, 07:23 AM   #10 (permalink)
Ram Year: 2000 Ram 1500
Engine: 318 ci
Default
Thanks! I have to give this a try!
My steering wheel has a lot of play in it compared to when it was new.. I've tested the idle arm and tie rod ends for play but there are none..It is also out of line and I am not sure if the gearbox is shot from all the dirt roads in its prime and I am hoping this would work will give it a try after work today.
MathersAlan is offline   Reply With Quote
Reply
Bookmarks
Tags
fix sloppy steering, fix steering diy, ram sloppy steering
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Steering shaft opinions. Unglued Tech Info 4 10-11-2010 11:37 AM
steering box meanwhitemopar Tech Info 15 07-05-2010 04:28 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
