Speedo not moving on 2k dodge ram 1500
asmith352
2003 Dodge Ram 1500
V6
I just noticed my Speedo stopped working today on my 2000 Dodge Ram 1500 V8 4 by 4
Can someone point me in the right direction to see how and where this may be fixed? Thank you
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
The speedometer gets it's reading from the ABS speed sensor located on the top of the rear differential. It's a pretty cheap part and easy to replace.
bingo!
I did mine, make sure you soak it in pb blaster everyday for a few days prior. There is a o ring seal that you must get out.
if you soak it everyday for a few days, it should pop out
radikio
