Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
To swap for a 5.7 Hemi or to build the 5.9 Magnum
This is a discussion on To swap for a 5.7 Hemi or to build the 5.9 Magnum within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
Cutting out the cat usually will only throw rear sensor code if it throws one at all. Often times it ...
Like Tree1Likes
Reply
Old 07-23-2016, 12:33 PM   #11 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Cutting out the cat usually will only throw rear sensor code if it throws one at all. Often times it throws nothing but it will run richer. The front 02 is the one that controls air/fuel ratio and will be seeing more air and to make up for it will push slightly more fuel. Not a huge problem but one to expect. The rear simply monitors cat efficiency so it might throw a code indicating a failing cat but nothing to worry about. Whichever throws a code if any can usually be cleared by using spark plug non-foulers to space it out of the pipe a little bit.
Sponsored Ad
Register to remove this ad.
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 07-23-2016, 12:40 PM   #12 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
These are all recent.
Muffler swap Dakota 5.9
5.9 ram procharged, Eddie heads, 10psi intercooled (found the boost number later on in another post) big cam,58mm tb
408 history with other tuners
Old 07-23-2016, 03:19 PM   #13 (permalink)
Default
Well that's alot of info to swallow lol I'll say 300 at the crank. I think I'm gonna be doing some parts research here soon lol thanks for all the help man it makes a huge difference and gives me an idea of where to start
Sent from my XT1045 using Tapatalk
zachl88 is offline   Reply With Quote
Old 07-24-2016, 12:34 AM   #14 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
It looks like you're going for the 360 build, nice choice
You may consider beefing up your transmission. You can get some nice upgrade kits that will greatly reduce the common problems with the 46RE transmissions for about $400.
Most commonly, the bands burn up and the solenoids go bad. Just getting a $200 band and solenoid kit goes a long way, especially if you plan on driving it hard or are going to tow with it a lot.
For towing, a tranny cooler is a must, you will fry it otherwise.
Old 07-24-2016, 04:12 AM   #15 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Shift kit, check valve delete, Hayden 405 cooler and you should be more than good for what you're doing.
__________________
Old 07-24-2016, 08:58 AM   #16 (permalink)
Default
I've been looking into trannys to just replace the 46re. I'm the 3rd owner of my 01 and the trans blew at 170,000 but it was not taken care of by previous owners. I can either upgrade my trans cooler or install a second stock cooler (from my parts truck). See this is where I get stuck because I'm very indecisive at times lol I have a whole other truck I could parts from and rebuild the trans to make it what I want, or buy an aftermarket HD trans. I've just never seen these 46re trans take a beating very well, then again I've only ever seen them stock.
Old 07-24-2016, 09:00 AM   #17 (permalink)
Default
Heres a quick question, something I ran into yesterday. How hard should it be to separate the transfer case from the transmission? I feel like I shouldn't have to pound and pry in all directions with hardly any results lol its still in the truck and its time for it to come out.
Old 07-24-2016, 11:42 AM   #18 (permalink)
Ram Year: 1998
Engine: Magnum v10
Default
You got all the bolts out? Even ontop? Nvm. I just remembered. It slides over the trans shaft. I had to split it like u would a wheel bearing hub assembly lol
joepizuro is offline   Reply With Quote
Old 07-24-2016, 01:56 PM   #19 (permalink)
Default
Yeah I removed all the bolts around the housing. So just slow and steady smacking and pulling
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
3.7 magnum swap to 5.7 L hemi BKHoldings Engine & Performance 5 04-25-2016 03:23 PM
LA for Magnum Swap Deblackmon3 Engine & Performance 11 11-25-2013 02:07 PM
5.9 magnum swap SteelHawk Engine & Performance 0 05-04-2013 01:43 AM
swap a magnum for a hemi? greenmachine15 Engine & Performance 5 02-09-2013 11:32 AM
02 magnum to 12 hemi swap??? dcoach222 Engine & Performance 20 12-19-2012 08:44 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
