Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > 2nd Gen DIY
2nd Gen DIY
Transmission swap compatabilty
This is a discussion on Transmission swap compatabilty within the 2nd Gen DIY forums, part of the 2nd Gen : 1994 - 2002 category!
I own a 1998 Dodge Ram 1500 2wd Laramie and a 1999 Dodge Ram van 3500 2wd. I was wondering ...
Reply
Old 01-12-2017, 01:07 PM   #1 (permalink)
Ram Year: 1998
Engine: 5.2
Default Transmission swap compatabilty
I own a 1998 Dodge Ram 1500 2wd Laramie and a 1999 Dodge Ram van 3500 2wd. I was wondering if the transmission in the van is the same as the truck and I could swap them out. The transmission went out on the van and the frame of the van is badly rusted through on the front end. It has several other issues and its not really worth the effort because of the crap frame. I was considering removing the transmission before I junk the van to rebuild. Never done it before but thought it would be fun to learn.
Can they be swapped?
Sponsored Ad
Register to remove this ad.
jackson4212 is offline   Reply With Quote
Old 01-12-2017, 04:42 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
They will bolt right up as long as they are both either the 5.9 or 5.2. Wait for dapepper to tell you which pieces you need to swap, if you need to swap.
Old 01-12-2017, 04:56 PM   #3 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
5.2/5.9 v8s are swappable. 8.0 v10/5.9 diesel to the v8s not possible.
98 46re to 99 46re only issue is going to be flexplate for correct engine and this isn't an issue if both are 5.9 v8s
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-12-2017, 05:04 PM   #4 (permalink)
Ram Year: 1998
Engine: 5.2
Default
Would the 5.2 have a flate plate I could put on the trans from the 5.9?
Old 01-12-2017, 05:06 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Just to verify, van is a 5.2 v8 and the 3500 is a 5.9 v8 correct?
If that's the case, to use the 5.2 trans you would need to use the 5.9 flexplate, which you should have in the 3500 already
__________________
Old 01-13-2017, 10:35 PM   #6 (permalink)
Ram Year: 1998
Engine: 5.2
Default
The van is a 5.9 and I would be moving that trans to a 5.2
Old 01-14-2017, 08:38 PM   #7 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Well the 5.2 flexplate then. Not a big deal
__________________
Old 01-23-2017, 02:42 AM   #8 (permalink)
Ram Year: 1998
Engine: 5.2
Default
Is the flex plate already on the truck I'm moving it to?
Old 01-23-2017, 12:43 PM   #9 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Should. If the trans and stuff in the 5.2 hasn't been pulled it'll have it. Otherwise your guess is good as mine lol
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission swap Joker65 General Discussion 4 10-21-2016 08:09 PM
Transmission swap hurstguy01 General Discussion 12 12-29-2015 12:44 PM
Transmission swap? sam67de Engine & Performance 4 05-26-2015 02:14 PM
Transmission Swap Tom991 General Discussions 5 09-08-2013 03:40 PM
Transmission swap-possible? the codes Engine & Performance 8 05-29-2013 12:44 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
