parked truck came out and it wont start there are no codes when u turn key all seems to be well dash works u can hear fuel pump but when i turn to start it all u can here is a click from starter relay and will not turn over if i use a jumper on relay it will turn over but not start have changed relay ignition switch pull all chassis grounds off scraped them and put back on pulled the fuse block out and cleaned all conections and the same problem ..... any ideas?
