New to dodge. Here is my story got a great deal on a 01 Dakota with a 4.7L. After some. Ignition work and now it starts. Major oil leaks and some knocking noises. The knocking travels seems like timing chain slap then it goes away then some lifter ticking coming and going then it sounds like it's in the lower end. Once started and put in gear holding the brake there is no noise until you throttle up any info is greatly appreciated.
