My build sheet:
Thank you for contacting the Ram Customer Assistance Center in regards
to a 2004 Dodge Ram.
If you plan on purchasing this vehicle or if you are the current owner,
please provide me with this update so that I can update our database.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*V9 Cloth 40/20/40 Bench Seat
-DV Dark Slate Gray
ALE Quad Cab Value Group
APAS Monotone Paint
A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMHS 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I60S Route 60 - CSX, Westboro, MA
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFVS 35 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NZDP Next Generation Engine Controller
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RAZP AM/FM Cassette Compact Disc Radio
RCKP Infinity Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTY P265/70R17 OWL All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WF2S 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email.
Sincerely,
Katie
Customer Service Representative
Original Message Follows:
US Customer Service - Dodge Brand Site
Brief Description:
Requesting build sheet
Comments:
2004 Dodge Ram 1500
