OK so I've tried to use the search engine on here and I haven't had any luck at all with what I'm trying to figure out. So here's my issue(s). I have a 2001 Ram Sport 1500 quad cab... I believe... I have 2 front doors and the suicide rear half doors. My passenger side rear door is seized and will not open. I have tried spraying the opening mechanisms with wd40 and no luck. Does anybody have an idea or tip other then cutting the door open and replacing everything and possibly having body work to do also? And my second question. I have a few local old schooler truck friends who keep suggesting I cut off my catalytic converter. I have 5.9 magnum. What exactly will removing the cat accomplish/do/cause? Thanks for any help guys.
