What is a good ODB2/CAN Scan tool
dpinvidic
This guy gets shotgun
Cave Creek, AZ
2014 RAM 1500 Limited
I am looking to get a scan tool. Any recommendations?
I would like to also read ABS and SRS codes.
And any Chrysler specific codes.
Thanks,
Dan
JohnD72
Charleston, SC
How powerful do want this scanner to be? Just a code reader or a full-fledged scan tool with live-data, module activation, CAN support, etc?
I have a CarMD reader that I was given as a Christmas gift which reads generic codes well but nothing more.
I also have an Auto Enginuity PC-based scan tool that is much more powerful and, yes, much more expensive.
dpinvidic
dpinvidic
Cave Creek, AZ
The more powerful the better. Really want Chrysler codes too.
Had a problem with tire pressure system. Would like to read that code if possible.
Dan
Sent from my SCH-I545 using Tapatalk
freddyx844
North Yorks. UK
Hemi 5.7 on LPG
Is there a reasonably cheap tool capable of reading the transmission temp on an 07 ram1500?
Sent from my GT-I9100 using Tapatalk
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Glowshift Transmission Temp Gauge. Since you have Galaxy there is also the Torque App for Android and then buy a BT dongle. Displays quite a bit of OBDII parameters but not sure on the trans' temp. Mine did not but i have a 04 but it may show for your year (CANBUS).
freddyx844
North Yorks. UK
Hemi 5.7 on LPG
An OBDII solution is preferred as there's next to nothing to install. I have used torque for years, sadly its limited to only a few working pids on the 3rd gen hemi.
hemihustlin
Montreal
How much do you want to spend is a better question. A good scanner is $$$$
And there is a difference between an OTC genisys evo at ~ 2500$ or a snap on starting at ~ 5000$
An evo is a good everyday scanner for most makes but if you are really serious go with the snap on especially for mopar applications it really excells, aside from being 52x faster and less frustrating than archaic evos
As i always say snap on + dodge = no time to **** around, its almost like they were made to compliment each other!!!
We also have a ford OEM scanner/laptop because fords suck and if you want to fix them fast and efficently its totally worth the money!
The local ford dealer also sends us thier HD alignments because they dont have the capabilitys or a good tech iim not sure but either way good for us!
JohnD72
Charleston, SC
AutoEnginuity
Here's a list of what the Auto Enginuity PC-based system will do on Chryslers. Some of these functions are model/equipment dependent, of course:
SBEC/JTEC System Tests:
◾EGR System Test
◾EVAP System Monitor Service Test
◾Erase All DTC Fault Codes
◾Generate Full Field Test
◾Gov & 3-4 Shift Valve Test - JTEC Only
◾Leak Detect Pump Test
◾Purge Vapors Test
◾Reset All Adaptive Memory Fuel Cells
◾Reset All Non-Volatile Memory
◾Reset CAM/Crank Misalignment
◾Reset CAM, Crank, and Sync Status Record
◾Reset Duty Cycle Monitor
◾Reset Engine Running Time Record
◾Reset Fuel Shut-off Record
◾Reset Intake Airflow Control Stepper Motor Position
◾Reset Trip Information
◾Set Sync Signal - JTEC Only
◾Set Minimum Throttle Position to Maximum
◾Torque Converter Clutch Test - JTEC Only
VPW-based System Tests:
◾ABS Bleed Brakes (EBC325, Mk20e, and Mk25e)
◾Tire Size Programming
◾Transmission Rear/Front Wheel Brake Torque Test
◾Transmission Pump Test
◾Transmission Quick Learn
◾Transmission TCC Break-In Test
◾Transmission Front Wheel Pinion Factor
NGC System Tests:
◾Injector Kill Test
◾NVLD Force Monitor Test
◾Purge Vapor Tests
◾Reset all On-Board Control Units
◾Report Part Number
◾Report Reflash Program Counter
CAN-based Module System Test and Configuration Support:
◾ABS Brake Bleed
◾ABS Initalize ECU
◾Auto Door Locks
◾Beltminder
◾Cylinder Performance Test
◾Current VIN Progamming
◾CAM and Crank Relearn
◾DRL Setup Configuration
◾EATX Quick Learn
◾Engine On Odometer
◾IMA Programming Injestors
◾Injector Quantity Adjustment
◾Module Configuration Setup
◾Retrieve Installed Module VINs
◾Tire Pressure Sensor ID Programming
◾Tire Pressure Trigger Configuration
◾Tire Pressure Pressure Calibration
RNLefever
York, Pa
I have a lauch crp 123, it is a decent scan tool for around a hundred dollars, but their customer service lacks, I also have a snap on solus ultra, I use that for more in dept stuff like tcm issues on volkswagen
twooldfarmers
SK and AZ
2014 Laramie Crew 4x4
I just ordered a scanner from good ole Harbor Freight that will also do ABS codes for a $100 bucks, now a bunch you guys are gonna' say I am going to get what I paid for 'at best' but I have been using a budget reader since buying my first one from the manufacturer in Phoenix about a dozen years ago for $300 and have always been able to solve my issues with them ....
chishola1
I use a obd2 usb cable there are plenty of software options to do what you need. Even if you need cables that are make/model specific it is still cheaper to do it that way.
tysondodge
Everywhere: Florida Native
I've used my android phone with torque and no issues. Also, since I have a bluetooth laptop, I've used ScanXL with no issues too.
CVX20
Ont,Ca.
2019 Classic Express
Snap-On was in the other day and they have one on sale.Regularly $4500 on for $1600.Didn't catch the model# as I wasn't interested,but sounded like a decent deal if you're in the market.Might be worth a call to them.
BTW This is in Ont.,Canada so it might not apply in the States.If it does it'll be a lot less than $1600 I would guess.
pwaite92
Oregon
Magnum 5.9L
They have used ones all the time. At my shop we traded our Genesys in for the Snap-on scan tool. Haven't heard my techs complain since. Haha
rippin209
I'm in California and a guy I know just paid $2700 for a snap-on
