May 2016 TOTM Winner (2nd Gen)
Status
Not open for further replies.
Cruizer
Ohio
2010 Sport 4x4 QC
Congratulations to NightMares for winning the May 2016 TOTM contest. Sweet lookin' 2nd Gen. You can add "May 2016 TOTM Winner" to your sig pic if you'd like.
May 2016 TOTM Winner (2nd Gen) - NightMares
Specs
Current Suspension:
BDS Long Arm Kit
BDS 5" Coil Springs
BDS Rear Shackle Flip
BD Diesel Adjustable Track Bar & Bracket
BDS Pitman Arm
BDS Dual Shock Bracket
BDS 5500 Series Shocks (Factory Shock Location Eliminated)
BDS Dual Steering Stabilizer Bracket
BDS 5500 Series Steering Stabilizers
Synergy Steering Box Brace
JKS Sway Bar Disconnects
Suspension Awaiting Install:
Dodge Off Road 7" Progressive Rate Coil Springs
BDS 5" Rear Block Kit (Eliminating stock & adding 2 inches)
Fox 2.0 Smooth Body Remote Reservoir Shocks (Front)
Fox 2.0 Emulsion Shocks (Rear)
Fox 2.0 IFP Steering Stabilizer (Revert to single stabilizer)
Fox Bump Stops
Current Wheel's / Tires:
Ultra Xtreme 102 Satin Black 16x10 4.5" Backspace
BFGoodrich All Terrain TA KO2 315/75R16
Current Performance:
Pacesetter Shorty Headers
Flowmaster Y-Pipe w/ Cat
Flowmaster Super 10 Series
AFE Cold Air Intake
Edge Evolution CTS2 Tuner
Comp Cams Double Roller Timing Chain
Monster In A Box Transmission
Drivetrain:
Nitro Gear & Axle 4.88 Gears
Yukon Master Install Kits with Timken Bearings
Yukon 1541H Alloy Shafts Front/Rear
Yukon 4340 Chromoly Outer Stub Shafts
5-760X U-Joints
Auburn Limited Slip Chrysler 9.25
Purple Cranium Spider Guard Chrysler 9.25
ARB Red Differential Cover Dana 44
Drivetrain Awaiting Install:
G2 CORE Air Locker with Mechanical Override Dana 44
ARB Twin Compressor
Yukon Minimal Install Kit with Timken Bearings
Current Exterior:
Fusion Winch Bumper w/ Rigid Dually Slots and Prerunner Bar
Rigid Industries 30” Radiance in Red
Rigid Industries D2 Hyperspots
Rigid Industries SAE Dually Fog Lights
LEDConcepts Color Morph Pod Halo Kit (SAE's & Hyperspots)
SLT Black Grille Painted Red
Engo 12000lb Synthetic Winch W/ Wireless Remote
Factor 55 Prolink Red
Factor 55 Fairlead
Rigid 6 Pod LED Rock Lights in Red
Spyder Black Sport Headlights
Putco XM-L2 Cree 9007 Headlight Bulbs (Low Beam)
Putco XM-L2 Cree 9003 Headlight Bulbs (High Beam)
Putco Plasma Amber 3157 Park/Signal Bulbs
Spyder G2 Tail Lights
Black Decal Package
Hand Laid Graphics
N-Fab Rear Runner
CSI 4x3" LED Flood Lights
Undercover Swing Case
Smittybilt Adventure Box
Raven Camper Shell
1A Auto Tow Mirrors with Signal/Power/Heat
Westin 3" Round Black Nerf Bars
TireGate Vertical Gate w/ Axe, Shovel, Hi Lift Jack
Smittybilt I Rack w/ License Plate, Roto-Pax Mount & 2 Gallon Roto Pax
Interior/Electronics:
Soundstream SDR-342B
Soundstream P1.1500D
ASC Downfire Box w/ 2 Kicker C10's
AutoMeter 2 Gauge A-Pillar Pod
Garmin GPS Mounted To Pod
Edge CTS2 Mounted To Pod
Covercraft Carhartt Seat Covers
Simco LTD White Face Cluster Replacement
Electronics Awaiting Install:
Cobra 29LXBT w/ Dual 4' Red Flexible Fiberglass Antenna's
SPOD Universal Touchscreen 12V Accessory Controller
Pumpkin 7” Touchscreen Android 4.4 Stereo
derekp
Buda, Tx
1990 5.9 Cummins
Congrats dude! Bout time you win one. Lol Also, how much lift would you say you have on your truck in one number? I'm having a hard time adding it up from the spec list.
NightMares
Boise, ID
Currently it's sitting at 5" in the front via spring and 4" in the back via shackle flip (it's actually 5" of lift, but my springs have a leaf removed for a little more flex)
I have 7" Dodge Off Road progressive rate coil springs to go in, along with a 5" block. In the rear it currently has the stock 3" block, I'm going to swap that out for the 5" and probably throw the leaf back in to get it to sit level.
Thanks man!
Congrats!!
Adam
Thanks man!
Congrats! I certainly enjoyed reading your build!
Thanks! I try to keep it as updated as possible, although it appears I've been slacking on the specs end of things haha.
I scratched the CORE locker pre-order and had an ARB installed in the front a few weeks ago. Among with some other stuff on here.
Status
mmcquinn
