Go Back   DODGE RAM FORUM - Dodge Truck Forums > Truck of the Month > Truck of the Month
Truck of the Month
May 2016 TOTM Winner (2nd Gen)
This is a discussion on May 2016 TOTM Winner (2nd Gen) within the Truck of the Month forums, part of the Truck of the Month category!
Like Tree6Likes
Closed Thread
Old 06-07-2016, 10:36 AM   #1 (permalink)
Cruizer's Avatar
4th GEN Site MOD
Ram Year: 2010 Sport 4x4 QC
Engine: 5.7L Hemi
Default May 2016 TOTM Winner (2nd Gen)
Congratulations to NightMares for winning the May 2016 TOTM contest. Sweet lookin' 2nd Gen. You can add "May 2016 TOTM Winner" to your sig pic if you'd like.
May 2016 TOTM Winner (2nd Gen) - NightMares
Specs
Current Suspension:
BDS Long Arm Kit
BDS 5" Coil Springs
BDS Rear Shackle Flip
BD Diesel Adjustable Track Bar & Bracket
BDS Pitman Arm
BDS Dual Shock Bracket
BDS 5500 Series Shocks (Factory Shock Location Eliminated)
BDS Dual Steering Stabilizer Bracket
BDS 5500 Series Steering Stabilizers
Synergy Steering Box Brace
JKS Sway Bar Disconnects
Suspension Awaiting Install:
Dodge Off Road 7" Progressive Rate Coil Springs
BDS 5" Rear Block Kit (Eliminating stock & adding 2 inches)
Fox 2.0 Smooth Body Remote Reservoir Shocks (Front)
Fox 2.0 Emulsion Shocks (Rear)
Fox 2.0 IFP Steering Stabilizer (Revert to single stabilizer)
Fox Bump Stops
Current Wheel's / Tires:
Ultra Xtreme 102 Satin Black 16x10 4.5" Backspace
BFGoodrich All Terrain TA KO2 315/75R16
Current Performance:
Pacesetter Shorty Headers
Flowmaster Y-Pipe w/ Cat
Flowmaster Super 10 Series
AFE Cold Air Intake
Edge Evolution CTS2 Tuner
Comp Cams Double Roller Timing Chain
Monster In A Box Transmission
Drivetrain:
Nitro Gear & Axle 4.88 Gears
Yukon Master Install Kits with Timken Bearings
Yukon 1541H Alloy Shafts Front/Rear
Yukon 4340 Chromoly Outer Stub Shafts
5-760X U-Joints
Auburn Limited Slip Chrysler 9.25
Purple Cranium Spider Guard Chrysler 9.25
ARB Red Differential Cover Dana 44
Drivetrain Awaiting Install:
G2 CORE Air Locker with Mechanical Override Dana 44
ARB Twin Compressor
Yukon Minimal Install Kit with Timken Bearings
Current Exterior:
Fusion Winch Bumper w/ Rigid Dually Slots and Prerunner Bar
Rigid Industries 30” Radiance in Red
Rigid Industries D2 Hyperspots
Rigid Industries SAE Dually Fog Lights
LEDConcepts Color Morph Pod Halo Kit (SAE's & Hyperspots)
SLT Black Grille Painted Red
Engo 12000lb Synthetic Winch W/ Wireless Remote
Factor 55 Prolink Red
Factor 55 Fairlead
Rigid 6 Pod LED Rock Lights in Red
Spyder Black Sport Headlights
Putco XM-L2 Cree 9007 Headlight Bulbs (Low Beam)
Putco XM-L2 Cree 9003 Headlight Bulbs (High Beam)
Putco Plasma Amber 3157 Park/Signal Bulbs
Spyder G2 Tail Lights
Black Decal Package
Hand Laid Graphics
N-Fab Rear Runner
CSI 4x3" LED Flood Lights
Undercover Swing Case
Smittybilt Adventure Box
Raven Camper Shell
1A Auto Tow Mirrors with Signal/Power/Heat
Westin 3" Round Black Nerf Bars
TireGate Vertical Gate w/ Axe, Shovel, Hi Lift Jack
Smittybilt I Rack w/ License Plate, Roto-Pax Mount & 2 Gallon Roto Pax
Interior/Electronics:
Soundstream SDR-342B
Soundstream P1.1500D
ASC Downfire Box w/ 2 Kicker C10's
AutoMeter 2 Gauge A-Pillar Pod
Garmin GPS Mounted To Pod
Edge CTS2 Mounted To Pod
Covercraft Carhartt Seat Covers
Simco LTD White Face Cluster Replacement
Electronics Awaiting Install:
Cobra 29LXBT w/ Dual 4' Red Flexible Fiberglass Antenna's
SPOD Universal Touchscreen 12V Accessory Controller
Pumpkin 7” Touchscreen Android 4.4 Stereo
Sponsored Ad
Register to remove this ad.
Cruizer is offline
Old 06-07-2016, 10:46 AM   #2 (permalink)
derekp's Avatar
Ram Year: 2007
Engine: 1990 5.9 Cummins
Default
Congrats dude! Bout time you win one. Lol Also, how much lift would you say you have on your truck in one number? I'm having a hard time adding it up from the spec list.
derekp is offline
Old 06-07-2016, 11:03 AM   #3 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
grats
__________________
BBartow is offline
Old 06-07-2016, 11:49 AM   #4 (permalink)
Drummin4jc's Avatar
Ram Year: 2012 RAM 1500 Express QC
Engine: 5.7 Hemi
Default
Congrats!!
Adam
__________________
Drummin4jc is offline
Old 06-07-2016, 12:29 PM   #5 (permalink)
nclark112's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
Congrats! I certainly enjoyed reading your build!
__________________
2013 RAM SPORT 4x4
Magnaflow 14" I 35x12.50r20 Firestone Destination M/Ts I 3" PA BL I Bilstiens 5100 @ 2.1
nclark112 is offline
Old 06-07-2016, 01:36 PM   #6 (permalink)
NightMares's Avatar
Ram Year: 2001
Engine: 5.9
Default
Currently it's sitting at 5" in the front via spring and 4" in the back via shackle flip (it's actually 5" of lift, but my springs have a leaf removed for a little more flex)
I have 7" Dodge Off Road progressive rate coil springs to go in, along with a 5" block. In the rear it currently has the stock 3" block, I'm going to swap that out for the 5" and probably throw the leaf back in to get it to sit level.
Originally Posted by BBartow View Post
grats
Thanks man!
Originally Posted by Drummin4jc View Post
Congrats!!
Adam
Thanks man!
Thanks! I try to keep it as updated as possible, although it appears I've been slacking on the specs end of things haha.
I scratched the CORE locker pre-order and had an ARB installed in the front a few weeks ago. Among with some other stuff on here.
Drummin4jc and derekp like this.
NightMares is offline
Old 06-09-2016, 07:48 PM   #7 (permalink)
Okiespaniel's Avatar
Ram Year: 2000
Engine: magnum, 5.9
Default
Nice 2nd Gen, Congrats!
__________________
Life is a Highway...I wanna drive it all night long...
My mods list is too long for my sig But you can find build pics here http://www.ramforum.com/members/okie..._10_23_11.html or http://www.ramforum.com/members/okie...isc_stuff.html The one Father you won't be able to Dodge!
Okiespaniel is offline
Old 06-10-2016, 07:26 PM   #8 (permalink)
Uaintlo's Avatar
Ram Year: 2015
Engine: 5.7
Default
looks good
__________________
Big John
2015 Express CC
3/6 drop on 24" Intros
Uaintlo is offline
Old 06-16-2016, 12:58 AM   #9 (permalink)
Ram Year: 2007
Engine: Hemi 6.1
Default
looks so good
Novia is offline
Old 06-22-2016, 08:25 PM   #10 (permalink)
MJG
Ram Year: 2016
Engine: Hemi 5.7
Default
congrats!
__________________
_________
2016 Ram Sport CC / 2015 Cayenne Diesel / 2012 991 C2S / 2010 Z4 Sdrive 35i / 2009 370Z track car / 1986 300ZX
MJG is offline
Closed Thread
Tags
2nd gen ram, may 2016 totm winner, truck of the month
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
May 2014 TOTM Winner Cruizer Truck of the Month 30 06-25-2017 10:13 PM
March 2016 TOTM Winner (Lifted) Cruizer Truck of the Month 24 06-25-2017 10:09 PM
April 2016 TOTM Winner (Lowered) Cruizer Truck of the Month 21 06-25-2017 10:08 PM
May totm winner OklaHemi Truck of the Month 43 03-26-2014 11:02 AM
August TOTM Winner wermbang Truck of the Month 49 06-03-2013 02:05 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
