Go Back   DODGE RAM FORUM - Dodge Truck Forums > Preferred Vendors > Super Chips
Sponsored Ads
Register to remove these ads.
Super Chips
Superchips Transmission Tuning Information
This is a discussion on Superchips Transmission Tuning Information within the Super Chips forums, part of the Preferred Vendors category!
Register to remove these ads. It's free! Hi Folks, I thought it would be a good idea to start a ...
Reply
Old 08-19-2010, 10:58 AM   #1 (permalink)
SilsHemi's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Thumbs up Superchips Transmission Tuning Information
Hi Folks,
I thought it would be a good idea to start a thread specifically for transmission tuning information. A place where you can grab starter shift schedules, talk about settings, ask questions, etc. If you want to share your current schedules, that would be great! I can always update the server with your schedule, so others give your effort a try. I included in this first post some general information and the link to the shift schedule website. This is a powerful program.
Thanks,
Sil
Some helpful information for Ram Forum members about the transmission options:
Originally Posted by SilsHemi
A synopsis of important information. Also, the transmission options FAQ is available here: Index of /superchips
__________________________________________________ _______________
Just an FYI to all and a very important step during the transmission options upgrade process.
In order to upgrade to the transmission options, when it's released, you must be VIN locked (your truck has to be tuned) during the update.
If you are not VIN locked (your truck is tuned) during the update, the upgrade will not go through.
This is a necessary step to electronically sign the legal waiver and authorize the upgrade.
__________________________________________________ __________________________________________________ ______________________________
There's shift logic built into the program. It won't allow you to stack shifts. Excellent safety feature.
The most important part of setting your shift schedule is, just be mindful not to cross your up and down shifts. That's where you can force an up and down shift loop. The excel graph gives you a good visual of how this could happen and is the number one reason you should use the graphs.
You can set the up and down shifts closer. The closer, the quicker the up and down shift will transition, but stay away from overlap.
I've attached two example graphs to give you an idea. The first one is fine, the second is not.
RIGHT:
WRONG:
__________________________________________________ __________________________________________________ __________________________________________________ __
Jeremy (one of our beta testers) was nice enough to host user shift schedules on his website. Thanks J.
These schedules are user schedules and aren't endorsed by Superchips. Totally done by the beta testers. We have a few schedules up now and we'll add more as we go along. This will be an easy way to access user shift schedules.
Please bookmark the URL.
Here's the website: Index of /superchips
New feature.
The feature will allow the user to choose Stock TM or Superchips TM, with either the Stock shift schedule or Superchips shift schedule. This will allow you to use Superchips tuning with any combination mentioned.
This is an either/or option. It does not offer the ability to fine tune like the transmission options will (when released).
It's a nice feature for those folks who prefer the stock schedule or stock torque management, with Superchips tuning.
The transmission options are VIN specific. They can't be moved from one VIN to another VIN.
The upgrade fee would apply to any new VIN.
Just a reminder.
Be aware that you have to choose your PCM model to view the correct PIDS for you truck in DAQ.
NGC4 2007+
NGC3 2006
NGC3 2004-2005
The reason I mention this is, you'll see both NGC3 and NGC4 in the menu.
For those who do not have Microsoft Office, there's a great open source office software suite called OpenOffice.
OpenOffice will allow you open and work the excel spread sheets we use for shift schedules.
Here's the URL: OpenOffice.org - The Free and Open Productivity Suite
Keep this in mind when sharing user shift schedules.
It's preferable you share shift schedules within the same model year. The reason being, throttle position percentages vary from year to year. Keep in mind they can still vary in the same year of truck in some circumstances.
Example: A 2007 Ram 2500 will not have the same throttle positions as a 2007 Ram 1500.
They may be similar in this case, but there will be variances.
Another tip.
When inputting a shift schedule, you may not have the max value in a particular TP% available. Don't worry. As you enter your values for the next shift points (2,3, etc.), you can go back to those previous shifts and your max value will have increased. Now you can input the value that previously could not be entered.
This is the shift logic safety feature kicking in and protecting you from stacking shifts.
Just a reminder in regards to torque management.
Setting torque management to 0% will not yield the best results. Leaving some TM in the mix produces a quicker shift.
The beta testers confirmed this during testing.
From the FAQ:
Q: Should I set torque management to 0% or leave in some percentage?
A: You should leave some TM in all of the shifts because the shifts will complete quicker with some load reduction. 0% doesn't necessarily mean a quicker shift; it means the engine is not reducing power during the shift. Think about it in the sense of friction, if you are applying torque to the transmission, the higher the friction. If you reduce it a little the lower the friction and this is a non-linear reduction. Too much torque and the truck will lag its shifts.
Just a reminder.
The shift schedules the beta testers provide on the web server are their own personal schedules. Superchips had no input in these schedules whatsoever and they will not be providing any USER shift schedules. This is totally a USER custom tuning product for your transmission.
The reason for this reminder is, everyone has different thoughts on how our trucks should shift. Invariably there will be folks who load up a personal shift schedule and not like part of the schedule. This is when the USER comes into play and makes the necessary adjustments in the schedule to their liking.
Again, this is a USER custom tuning product. Please keep that in mind when working with the tuning.
__________________
2008 Dodge Ram 1500 QC HEMI
Superchips Cortex 3950
Aero Turbine 3030XL
Magnaflow Y-Pipe
Hellwig Sway Bar
SilsHemi is offline   Reply With Quote
Old 08-19-2010, 11:28 AM   #2 (permalink)
Banned
Ram Year: 2004
Engine: 5.7
Default
Great idea Sil! I will add some schedules when I get home.
Off_Road_Teacher is offline   Reply With Quote
Old 08-19-2010, 11:58 AM   #3 (permalink)
SilsHemi's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
Thanks J!
__________________
Aero Turbine 3030XL
Magnaflow Y-Pipe
Hellwig Sway Bar
Old 08-19-2010, 01:21 PM   #4 (permalink)
ramhunter9's Avatar
Administrator / Owner
Ram Year: 1994
Engine: 7.5L
Default
i would love to post my schedule but i cant figure out how to post it here ?
I can e-mail it to you if you pm me your address
__________________
RamForum.com Administrator/Owner/Vendor
Click the link for info
DB Truck Customs Facebook Page (Click Here)
dbtruckcustoms@gmail.com FOR ALL YOUR PARTS NEEDS or installs email/PM me for a price quote. If you want it chances are I can get it at a very good price ! Web Sight Coming Soon !!
ramhunter9 is online now   Reply With Quote
Old 08-19-2010, 01:50 PM   #5 (permalink)
jusjay727's Avatar
Ram Year: 04
Engine: badass 4.7l
Send a message via Yahoo to jusjay727
Default
i need to type my schedule up into a spreadsheet and figure out how to graph it and then i can get it on here....if i can figure out the graph if i post my spread can somebody help me...i need to run some errands and then ill type it up....
__________________
onebadass4.7bitches
"I'm the kind of guy that deserves to drive a Ram"
jusjay727 is offline   Reply With Quote
Old 08-19-2010, 01:51 PM   #6 (permalink)
ramhunter9's Avatar
Ram Year: 1994
Engine: 7.5L
Default
lets try ...
fail
__________________
Old 08-19-2010, 01:53 PM   #7 (permalink)
SilsHemi's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
Dave,
Sent you a PM.
Thanks,
Sil
__________________
Aero Turbine 3030XL
Magnaflow Y-Pipe
Hellwig Sway Bar
Old 08-19-2010, 01:54 PM   #8 (permalink)
SilsHemi's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
I'm also looking for some tweaked 2006 5.7 schedules to place on the server and looking for some 2007, 2008, etc., 4.7 schedules as well.
If you have a schedule in excel format, post it and I'll put it on the server.
Thanks,
Sil
__________________
Aero Turbine 3030XL
Magnaflow Y-Pipe
Hellwig Sway Bar
Old 08-19-2010, 02:00 PM   #9 (permalink)
ramhunter9's Avatar
Ram Year: 1994
Engine: 7.5L
Default
sent bud , thanks
__________________
Old 08-19-2010, 02:53 PM   #10 (permalink)
SilsHemi's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
It's on the server Dave. Thank you.
Sil
__________________
Aero Turbine 3030XL
Magnaflow Y-Pipe
Hellwig Sway Bar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
NEW Transmission Problems OlDirtyJohn Tech Info 19 08-10-2010 03:17 PM
My transmission problems OlDirtyJohn Tech Info 13 08-05-2010 01:16 PM
transmission throttle valve harleydave2 Engine & Performance 1 07-31-2010 03:03 PM
superchips or diablo ? ramhunter9 Engine & Performance 42 07-11-2010 10:23 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
