Go Back   DODGE RAM FORUM - Dodge Truck Forums > Member's Area > The Great Outdoors
The Great Outdoors
atv help...calling all my mechanic buddies!
This is a discussion on atv help...calling all my mechanic buddies! within the The Great Outdoors forums, part of the Member's Area category!
Well once again im working on the old beast! Its a 1997 Honda Foreman 400. I went out the other ...
Like Tree1Likes
  • 1 Post By NYCruiser
Reply
Old 12-20-2013, 08:12 AM   #1 (permalink)
GlOcKnRaM's Avatar
Ram Year: 2012
Engine: 5.7L V8 Hemi
Default atv help...calling all my mechanic buddies!
Well once again im working on the old beast! Its a 1997 Honda Foreman 400. I went out the other day to start it and it wouldnt turn over. Almost like the battery didnt have enough juice to turn over the stater. I have a video of the noise it makes and if needed Ill upload it, but it just makes a ticking noise coming from the battery and starter. Its seems I have a bad ground somewhere draining the battery or a bad starter?? Before replacing the battery and solenoid we used to have to keep it on a charger for it to start. Replacing these two fixed it for about a month, now its back to the same old problem. Any help would be appreciated, as when it comes to electrical Im a little rusty.
Sponsored Ad
Register to remove this ad.
GlOcKnRaM is offline   Reply With Quote
Old 12-21-2013, 06:50 AM   #2 (permalink)
mattman_13's Avatar
Ram Year: 2012
Engine: hemi 5.7
Default
I had an issue like that on my streetbike. It would just tick like trying to turn over. Then if I jumped it it would run as normal but then the gauges would stay on even after the key and off button were off. It ended up being A LOT of corrosion on one of the wiring harnesses (took me days going through wiring). Doubt it's something like that The honda 300/400 foremans were beasts. Does it have a pull start or am I going crazy?
No exaggeration my grandfathers 1989 300 would sit all year with sea foam in the tank you could go outside and kick it a couple of times and ride it like nothing ever changed.
Maybe try a trickle charger for a few days.
Goodluck man
__________________
TEAM BULLY'S PERFORMANCE
mattman_13 is offline   Reply With Quote
Old 12-21-2013, 07:20 AM   #3 (permalink)
NYCruiser's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
I would check all the wiring, connectors, plugs, etc for corrosion. Get some dielectric grease handy and use it after checking when you reconnect stuff.
In the meantime, I would install a switch on the battery to make sure I can shut it off when stored.
GlOcKnRaM likes this.
NYCruiser is offline   Reply With Quote
Old 12-21-2013, 08:04 AM   #4 (permalink)
Ram Year: 2013
Engine: 5.7
Default
I just went through an entire rebuild on a foreman 400. Sounds like you have something draining the battery. I have the manual on my computer if you send me your email I can email it to you.
bmxnick7 is offline   Reply With Quote
Old 12-21-2013, 12:56 PM   #5 (permalink)
GlOcKnRaM's Avatar
Ram Year: 2012
Default
That would be awesome..its [email protected].
I went to auto zone this morning to test the battery and starter and they were fine! So its got to be something draining the battery, or a short/ bad connection somewhere.
Old 12-21-2013, 12:58 PM   #6 (permalink)
GlOcKnRaM's Avatar
Ram Year: 2012
Default
Goodluck man
They are beasts! Besides this issue, I can always rely on it! It does have a pull start, and that does work..just takes more pulls than I'd like lol..its easier to just press a button!
Old 12-23-2013, 12:41 AM   #7 (permalink)
Cowboy345's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
its defiantly the wiring. Just check everything maybe a voltmeter would help but you have something draining the battery.... I dout its a short.
__________________
2011 SC/SB Express: K&N CAI, Flowmaster Outlaw series, 5in muffled tips, ground force 2in drop, black dual headlights, professional tinted taillights, hellwig sway bar & endlinks, billet tech catch can....
Cowboy345 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My buddies 4th gen Lostnwalmart Lowered 27 10-29-2012 02:20 PM
my buddies Ram 05singlecabHEMI Photos & Videos 9 09-16-2011 10:50 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
