Go Back   DODGE RAM FORUM - Dodge Truck Forums > Member's Area > The Great Outdoors
The Great Outdoors
Playing with kydex.... Again
This is a discussion on Playing with kydex.... Again within the The Great Outdoors forums, part of the Member's Area category!
New holster for a little p22 Got one more to make later this week /weekend but I like this one ...
Like Tree1Likes
Reply
Old 10-21-2013, 06:32 PM   #1 (permalink)
truckin151's Avatar
Ram Year: 2013 sport
Engine: 5.7
Default Playing with kydex.... Again
Got one more to make later this week /weekend but I like this one quite a bit.
Sponsored Ad
Register to remove this ad.
__________________
2013 RAM 1500 SPORT - Let the modding begin.... Again
truckin151 is offline   Reply With Quote
Old 10-21-2013, 07:36 PM   #2 (permalink)
Sharp Charge's Avatar
Ram Year: 2014
Engine: 6.7
Default
Nicely done!
__________________
2014 Ram 2500 Laramie. Toyo Open Country A/T's, BAKFLIP Tonneau cover, NFab nerf bars. Atomic LED clearance lights.
Sharp Charge is offline   Reply With Quote
Old 10-21-2013, 10:25 PM   #3 (permalink)
Stangshcky12's Avatar
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
I was gonna give it a try but I already have to many unfinished projects
I actually have a bunch of leather but never got any kydex so I guess this is technically one I started and never finished too haha
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Stangshcky12 is offline   Reply With Quote
Old 10-21-2013, 10:45 PM   #4 (permalink)
truckin151's Avatar
Engine: 5.7
Default
Thank you,
__________________
Old 10-21-2013, 10:48 PM   #5 (permalink)
truckin151's Avatar
Engine: 5.7
Default
I just can't see spending $80+ on a holster that may or may not work the way I want it t, instead for that price I can make 8-10 of them that I can modify or adjust without feeling like I wasted a bunch of mone.
__________________
Old 10-22-2013, 06:56 AM   #6 (permalink)
mattman_13's Avatar
Ram Year: 2012
Engine: hemi 5.7
Default
sweet. where do you get your supplies?
__________________
TEAM BULLY'S PERFORMANCE
mattman_13 is offline   Reply With Quote
Old 10-22-2013, 12:12 PM   #7 (permalink)
argray90's Avatar
Ram Year: 2012
Engine: 4.7
Default
How hard is it to do? I have not heard of doing it yourself. I would be interested on how you did it and where you got your supplies also. Thanks!
argray90 is offline   Reply With Quote
Old 10-22-2013, 12:12 PM   #8 (permalink)
argray90's Avatar
Ram Year: 2012
Engine: 4.7
Default
Looks good btw!
Old 10-22-2013, 12:44 PM   #9 (permalink)
I Got a Hemi!'s Avatar
Ram Year: 2013
Engine: 5.7 Hemi!
Default
That is awesome. I didn't realize that was a DIY type project. Looks good.
__________________
2013 Ram 1500 Express Crew Cab 2WD - It's debadged, Volant Fast CAI and Dynomax catback, folding rear seat...I'm just getting started!
I Got a Hemi! is offline   Reply With Quote
Old 10-22-2013, 03:42 PM   #10 (permalink)
truckin151's Avatar
Engine: 5.7
Default
Its not horribly difficult to do, just takes a couple hours out of your day and a lot of looking at what parts you like and what parts you dont from various holsters out there already. You can pick up an 8-10 pack of 12"x12" kydex sheets on Amazon for $60-$70, rivets or chicago screws and belt clips from Tandy leather. Total for the IWB holsters and OWB holsters I have made for myself and others I've barely touched 4 sheets. If I were to out right buy the holsters I would be sitting around the $200-$300 mark easilly so the inevestment is well worth it.
Basic things you need,
Oven
Heat gun
Press (I use some Hi-Density foam and 2 - 2ft square pieces of partical board and some velcro straps, really crude press)
Dremel
Drill
Neopreine Washers/O'rings
- Take some blue painters tape and a wooden dowell and tape it to your gun along the slide between your front sight and rear sight, idea is to form a sight channel when molded otherwise you will never be able to get the gun out. Also add tape to any areas you want smoothed out or show less deffinition.
- Heat the oven to 350*-370*
- Place kydex sheet (usually just use half a sheet) on cookie tray and pop it in the oven for 5-7min. (it will smell up the house so do it when wife or parents are not home).
- Layout the press and gun (UNLOADED) so you can quickly take the sheet of kydex out of the oven and lay it on the press.
- I usually lay the sheet down on one half of the press, and then depending on type of holster, either place my gun on top and fold the kydex over it OR place a small piece of partical board ontop of the gun, and put the top piece of the press on. Sandwich the two together as tighly as possible and strap it down. Many use clamps to get the tightes possible fit, I strap it down and sit on it for about 5min.
-Take the press apart and kydex should have molded to the gun. If it has not you will have to reheat the kydex and leave it in longer until it is very plyable.
- Once you have the desired form, pop the gun out of the kydex and layout the look of the holster with a pencil, marking the holes for the screws/rivets and belt clips or loops.
-Once everything is laid out, take a dremel and cut away the excess kydex and then take a sanding bit and go around the edges.
-Drill the holes for the screws/rivets
-WASH the inside of the holster out
-Assemble (use some thicker Neopreine o-rings inside the 2 pieces of Kydex for an OWB type holster, this will give you some retention adjustments).
-Take a heat gun or hair dryer to heat and form any places that need a little extra bend or a little more definition.
- Then draw/holster/draw/holster your firearm until it feels right, making adjustments here and there to get the fit nd finish just right. Just remember that after every cut or grind to smooth out the edges and wash the inside of the holster out. Otherwise you end up with plastic shavings coating the gun and getting into places you dont want it to.
It sounds like a lot but it really isnt that bad and there are TONS of information on it out there. You really just need to get it laid out a head of time to aviod any issues that may arrise during the molding process (if there is a latch at the end of the barrel that sticks out, make sure it has a path to travel to get in and out).
This is my method, there are many many others out there.
argray90 likes this.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
playing with my rims loki223 Photoshop 7 08-12-2012 09:21 PM
New mod, playing it safe. MoparSickness77 Interior 12 02-15-2012 08:08 PM
Me playing around with a projector 0212353 Retro Shop 20 11-22-2011 11:48 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
