Go Back   DODGE RAM FORUM - Dodge Truck Forums > Member's Area > The Great Outdoors
The Great Outdoors
Wanting to build an AR and need some help.
This is a discussion on Wanting to build an AR and need some help. within the The Great Outdoors forums, part of the Member's Area category!
Since the recent purchase of my XDs .45 and Beretta PX4 compact 40, I have caught the gun and shooting ...
Like Tree1Likes
Reply
Old 02-21-2014, 10:24 PM   #1 (permalink)
VolsRam's Avatar
Ram Year: 2004
Engine: 4.7L
Default Wanting to build an AR and need some help.
Since the recent purchase of my XDs .45 and Beretta PX4 compact 40, I have caught the gun and shooting bug. I've always loved firearms and hunting, but now it's gotten bigger. I would like to build an AR and have no idea where to start. I've researched parts and different websites with steps, but not sure which direction to go.
What I would like to have is a rifle I can have fun with on the farm shooting targets as close as 10-15 yards, to something I could use for hunting deer. Possibly something I can swap out firing pins to change calibers for plinking with cheaper ammo. I like the tactical appearances, with a rail to possibly add accessories. Any and all help is greatly appreciated. Also, if you have websites with good prices, easy to follow steps, or anything else you feel I need that would be great.
Sponsored Ad
Register to remove this ad.
__________________
Reba - 2004 Dodge Ram 1500 4.7 Magnum V8
Standard Cab Long Bed - 4x4
Gibson Shorty Headers, 3" True Dual Exhaust, Dual 3" Inlet/Outlet MagnaFlow Highflow Cats
VolsRam is offline   Reply With Quote
Old 02-21-2014, 10:59 PM   #2 (permalink)
iSlacker816's Avatar
Ram Year: 2001
Engine: 5.9 (360ci) Magnum
Default
I've thought of this as well. I'd be interested in what the guys post in here!
__________________
2001 1500 Off Road Edition/5.9 Magnum/4.10 Gears - 16" XD798 Addict's - 33" Nitto Terra Grappler's - Linex Spray In - Glasspack Duals w/ Tips - Dash Cap - Spectre CAI Superchips Flaspaq 3865 - Husky Molded Floormats - Hughes Engine's Plenum Kit - Moose Mirrors - Strobe Light Kit - Vent Visors - LED Interior Lights
iSlacker816 is offline   Reply With Quote
Old 02-21-2014, 11:22 PM   #3 (permalink)
B-g-K's Avatar
Ram Year: 2014
Engine: Ecodiesel
Default
Go for 1:7 twist barrel if you want to shoot deer and you're going to stick to 5.56. The handle the heavier loads better than a 1:8 or 1:9. I personally had a S&W m&p15x, before I tragically lost all of my firearms in a freak canoeing accident.
B-g-K is offline   Reply With Quote
Old 02-21-2014, 11:43 PM   #4 (permalink)
Sharp Charge's Avatar
Ram Year: 2014
Engine: 6.7
Default
Gotta watch those damn boating accidents....
OP, to begin your build (if you decide to go this route over buying a complete off the shelf rifle) you need to buy a stripped lower receiver. You can not get this piece via mail, it has to be bought via a dealer. You can usually find them at gun shows from several distributors. You will need a few specific tools if you go forward with a build. You'll need an AR armorers wrench, torque wrench, upper vice block, bench vice and a set of roll pin punches. That should be about all, off the top of my head.
By building it piece by piece, you can control cost and spread it out over time. Don't pay more than about $120 for the stripped lower. You can usually find them between $80 and $120, when people aren't gouging. Try and find CMMG, Spikes, LMT and DSA lowers. Next comes the lower parts kit or LPK. This will have all the pins, springs and trigger pieces, etc. This goes from about 80-150 bucks depending what else you want in it. You'll then need a rear stock and receiver extension (sometimes called a buffer tube), buffer and buffer spring. That should round out the lower.
As for the upper, you're really not going to simply drop in a firing pin and barrel to swap calibers. You can swap uppers easily however. So say you want a 22lr dedicated upper, that's simply popping the 2 takedown pins and putting on the other upper. You can not get a .308 ar and pin on a 5.56. I've only seen 1 specific maker where this capability is interchangeable.
Building them isn't terribly hard, just need some time and a few specific tools. If you were closer I'd help ya out. Let me know if you want more info.
Slidder likes this.
__________________
2014 Ram 2500 Laramie. Toyo Open Country A/T's, BAKFLIP Tonneau cover, NFab nerf bars. Atomic LED clearance lights.
Sharp Charge is offline   Reply With Quote
Old 02-22-2014, 01:30 AM   #5 (permalink)
VolsRam's Avatar
Ram Year: 2004
Engine: 4.7L
Default
I appreciate your help and the info about pricing. As for the upper, can the swap be done for a 308 and 556 like it can to a 22? Also, what are some pricings I should expect to see on uppers?
__________________
Old 02-22-2014, 08:21 AM   #6 (permalink)
Riccochet's Avatar
Ram Year: 2017
Engine: 5.7 Sport
Default
5.56 and .308 are not interchangeable on a single lower. .308 requires an AR10 style lower while 5.56 requires an AR15 style lower. Different designs. You can, however, use a single AR15 style lower for uppers in calibers like .300BLK, 6.8SPC, 6.5 Grendel, .458 SOCOM, .50 Beowolf, .22LR. Just make sure the caliber marked on the lower is "Multi" and you're all set.
For a quality lower I'd suggest Mega Arms.
Riccochet is offline   Reply With Quote
Old 02-22-2014, 09:33 AM   #7 (permalink)
h2oman's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
All lowers are now machined at only 3 places. All are milled from T-7075 aluminum. This was not the case in the past but it is now. The only thing different from lower to lower is each companies mag well design and roll marks. Cosmetics aside, all new uppers and lowers are essentially the same. The exception is polymer lowers. Stay the hell away from them. So, unless you have one in mind for looks, just buy the cheapest. Also, if you can find blems you can save a lot more money. It's an AR. It's supposed to be blemished. Have fun.
__________________
A free people ought not only to be armed but disciplined; to which end a uniform and well digested plan is requisite: And their safety and interest require that they should promote such manufactories, as tend to render them independent on others, for essential, particularly for military supplies.
******** ---George Washington's First Annual Message to Congress (January 8, 1790)
h2oman is offline   Reply With Quote
Old 02-22-2014, 09:43 AM   #8 (permalink)
Ram Year: 2014
Engine: 6.7
Default
The Colt 901 is the only rifle that can swap from 7.62 down to 5.56. I've never handled this rifle and don't know how well it performs that function.
Colt 901 Modular Carbine .308/.223 – New Gun Review – LE901-16S
__________________
Old 02-22-2014, 11:53 AM   #9 (permalink)
VolsRam's Avatar
Ram Year: 2004
Engine: 4.7L
Default
Am I really saving money by doing a build myself instead of buying a completed gun? I understand that accessories will cost money, and that would be the same case for both scenarios. But if you have a strictly stock AR that can function and fire like it needs to, what is the cost saving I would see?
__________________
Old 02-22-2014, 12:09 PM   #10 (permalink)
quietpeen's Avatar
Administrator
Ram Year: 2016 1500 Sport Crew Cab 4x4
Engine: Hemi 5.7
Default
you can build a functioning ar for right around $600 if you hit the deals right. Once you start customizing the price can raise quickly
__________________
RamForum.com Administrator
quietpeen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need some help, wanting to go lower then my current 3/5.5 Myram1500 Lowered 5 01-16-2014 04:28 PM
Wanting Nav Unit Hammer75 Audio & Electronics 18 07-12-2013 05:00 PM
Wanting more power Jhodge2010 Engine & Performance 7 05-10-2013 10:46 AM
wanting to do 4.56 gears in 2013 mikey j General Discussions 4 01-04-2013 10:43 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
