12-11-2010, 08:03 PM
#17 (permalink)
Ram Year: 2006
Engine: CTD
The rubbing issue has been resolved...for now. On the driver's side there was a hump in the inner liner causing most of the rubbing. I heated it up and pushed it back with the head of a hammer. While pushing towards the rear on the liner, I noticed it moved at least a 1/4", maybe more. I also noticed that the fender lip on the bottom (inside the wheel well) was outward, a few light taps with a rubber hammer moved it away from the tire, and with that the inner liner moved away from the tire as well.
So, I now have clearance for normal driving, but any articulation and the rubbing will be back. I drive fit the flares, and they may have to trimmed a little where they wrap inward at the bottom of the wheel well to clear. But again, under articulation rubbing will be a problem.
I think I'm good for now as I don't go off-roading and unfortunately I haven't been hunting in the last 5 years or so. But as soon as my RV is gone, she's getting lifted. And when I'm ready to do that, I will certainly contact you first, Jeff.
Again, thanks for your time and help, it is greatly appreciated.
