13+ headlight harness
bobbo7915
Massachusetts
CTD 6.7L
hey just a heads up, I received the headlight harness for a 13+ on friday, installed that night and had a slight issue getting the connectors to seat properly. not sure if it was just my truck or not but the parking light connector would not click together, had to shave a little off of the hook that the factory connector latches onto.
once i fixed that everything worked perfectly....no to decide if i want HID's...
1500ram12
5.9L Cummins
I think it's a combination of each individual truck and each individual adapter. Some fit perfectly. Some are a little loose (mine was in this category) some just don't want to seat properly.
Sent from my D6708 using Tapatalk
iam_canadian22
northern ontario
You want hid's, trust me, then you will probably want a fxr retro lol
B
bobbo7915
Massachusetts
CTD 6.7L
i know i probably want HID's...but these projectors even with just the HIR2 bulbs are such a huge improvement over the factory quad lights with the factory bulbs or with silverstar bulbs...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Got it!
Hoping to get out and get some shipping done with USPS today, FedEx isn't doing pick ups today. ;)
TY sir!
B
bobbo7915
Massachusetts
CTD 6.7L
also, quick question. i noticed last night that my driver side cutoff line is slightly tilted and not level. is that just a quick fix by rotating the projector a bit? guessing i should have been more careful taking the ty-wrap off when i installed the TYC's
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Can't change the way they are......though these headlights have a lot of play in the fender. Might just need a slight move of the light in the fender.
iam_canadian22
northern ontario
On the 13+ trucks there is actually an adjuster under the bolt that inside by the grille to tilt up and down a bit im assuming its for that very reason, if the inside has to go up you can maybe try adding a washer there to even it out a bit
B
bobbo7915
Massachusetts
CTD 6.7L
i braved the frigid temperatures last night and got my HID's installed..played some tetris and got everything inside of the headlights, may need to pull the passenger side apart again and rearrange so i can adjust as it is slightly lower now and i cant get any adjustment out of it currently.
thanks again for the awesome service and products!
now....HID for the highs?
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
Exactly why I left my stuff out of the housings...:)
B
bobbo7915
Massachusetts
CTD 6.7L
just to follow up on this, after driving around for a week or so i was able to adjust the headlight aiming WITHOUT removing all the parts from the housings....everything shifted around and got settled enough to allow me full adjustment!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
lucky!
