Damaged 2013's
Leveil22
I sold my OEM headlights to someone the post office severely damaged they broke the projector mounts inside. I was inquiring if that's repairable ?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
only if you rip the lens off and repair........
Can't get to the mounts without ripping the lens off bud.
:sorry:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I would need to see as detailed pics of the damage that you can get me. Sometimes, they royally F up the insides.......if it simply snapped the lower mount (assuming its the one right below the projector) - its a little better. But, need more info before I throw out a $$ amount.
L
Leveil22
Here's one
L
Leveil22
Next one
L
Leveil22
Next
L
Leveil22
This one
L
Leveil22
And this
L
Leveil22
This tab
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
so it broke both lowers, and then the inner lower it broke through the housing itself. Top mount is pulled off the adjuster?
I think you need to call it a day.........I hope for your sake they were insured, and packed well.........
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
anything is fixable........but at the end of the day, I've probably got a set of broken tab ones that I could easily repair and sell you for about the same cost that it would run to rip those open, repair everything and reseal.
L
Leveil22
Can you send me a quote for a set
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
a full set of 13s would run $600 with repaired tabs. just depends on availability. I know I have a set at the house right now that needs the tabs repaired
L
Leveil22
I found a set on ebay with broken tabs how much would you charge to fix
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
What are they asking for them?
By the time they are shipped to me, I fix ($65 I guess?) and ship back out........well, not sure how much you'd be saving over the ones I already have here.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
not bad at all.
So........stupid question. He does have the tabs right? I mean.........can't repair them if they aren't there.
