I like the write up, and this will be my first mod to my truck.
Only thing I cant get a straight answer on is what I need to run HIDs in high beams along with the low beams. Do I need a separate 9005 wiring harness or just the high beam splitters from retrofit source?
I'm going to order the projector HID kit thru you guys at Retro Shop. I've emailed Retrofit Source but they kept suggesting I order the projector upgrade kit. I'm not comfortable taking my headlights apart yet.
I'm just trying to get everything figured out before I pull the trigger on this.
Thanks for the help in advance.
I tried the link on the original post, but apparently this product doesn't exist any longer????
I had to find 9012 bulbs for mine.. The 9006 bulbs in that housing would never aim the right way the lights would point down and left. Changed to 9012 and no issue. Just thought I'd share
I'm having issues with the passenger side light. It has troubles firing every time. I disabled all the illuminated entry options in the EVIC so as not to wear out the ballasts, and i don't use the auto setting for the lights.
So, when i do turn the lights on, the passenger will just flicker for a sec then stay off while the driver side turns on every time.
Sometimes it takes 5 or 10 tries before the passenger side fires.
Also - it might be worth noting that its quite cold here at the moment - around 10*F.
Any ideas what the issue might be? I checked the ground on that side (i made my own for it) thinking maybe it wasn't solid, but that doesn't appear to be it. Also, both red lights on the relays are on, even if both HIDs don't fire.
Out of ideas @ the moment.
if you want us to do a full retrofit, we can use your lights, or start with a new set here. With shipping from Canada.......its rare that I get a set to work on from up there. Downtime + shipping = not worth it.
If you want a drop in kit, just nab one - I'll ship it I don't have to have your lights for that.
The blue is nice! I will try to take a pic tonight.
