The TYC (or OEM) projectors take this kit here -
https://shop.retroshop.us/ProductDetails.asp?ProductCode=4G.13.HIDs
Couple things to keep in mind:
- 35W is plenty
- Most go 5K
- Canbus vs Full harness Both work great, your call on how much you'd like to wire in.
Now.....for YOUR specific truck, you have duals on yours. IF you want the projector in the new 13s to act as both the low and high beam (where the projector cutoff lowers and you have the high beam halogen bulb on at the same time) you will have to select the Mopar specific harness on the HIDs, and then you need this diode -
https://shop.retroshop.us/ProductDetails.asp?ProductCode=Diode
Again, that is on YOUR truck, as you have the duals on there now. This doesn't apply to all trucks (or people reading this post).
