gray8188
I have a 2010 dodge ram crew cab with the quad headlights. I'm wanting to do hid's with whatever is required. I don't want any flickering or any other issues. You guys seem like the go to can you tell me what I need? Thanks
Here's what you'll need if you are simply wanting a drop in HID kit - https://shop.retroshop.us/ProductDetails.asp?ProductCode=4G.HIDs
Most go with the 35w, 5K H11 and canbus adapter setup. (click the "?" next to each option to see details)
Correct!
The 50w also results in some loss of color rating, for example a 5k bulb at 35 will be a whiter light than the same bulb with 50w on it, just something to keep in mindOkay awesome thank you. And I see that the 50 watt kit will give a little more output at the cost of the life of the bulb. Is that the only downfall? Otherwise seems like it may be worth it to step up to the 50 watt kit.
