2011-2013 front end conversion
808ram1500
Big Island, Hawaii
4.7L
I have a 2011 ram 1500. What would it take to convert to a 2013 front end? Is a grill and bumper all that is needed?
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
There were some changes to the front area between 2012 and 2013. I think the hood is different were it reaches the grill, I think it is higher. The fascia between the bumper and grill is taller, do a side by side comparison. Mounting brackets are probably different also.
This doesn't mean it can't be done but, just would take some work. There are a few people who put a 2500/3500 bumper on a 1500 so if you have the know how I am sure it could be done.
nvre
Wyoming
2011 ram 1500 want to covert to 2013 ram 3500 tradesman front bumper can anyone know what need to change and where to get brackets to make it work
If you have the tools & the time, you & at least one other person can do it
You never mentioned are both front sections made of Plastic or Metal
2012 Grille & valance are shaped squared off at the bottom corners, just like the grille emblem at the top
2013 Grille & valance are shaped differently, the bottom of the grille corners are cut off, just like the top of the grille emblem
I would get the grille that you want to install
Then remove the current grill & set it aside
Then remove the bumper valance & set it aside
Now test fit the replacement grille
You can remove the grille inserts to make the grille lighter
1Popeye
