Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
There are some users who had the upper control arm ball joint going bad if you raise the bil's higher than 2.1, so most people go ahead and buy zone, mevo, or moog UCA's while putting new shocks in
in either late model 2012's or 2013's they changed the upper control arm design and its not as robust. When leveling it can put more stress on the ball joint causing it to pop out.
since you have a 2009 you really don't have to worry as its not common with the older design.
