FM radio no sound
vanila540i6
No sound when in FM radio.
Cd works with sound
Aux works with sound
Sat (although not active) has sound
Any thoughts ...or has this happened to anyone else?
Sent from my SM-N910V using Tapatalk
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Sounds like part of your radio died, the receiver/tuner for the FM side. AM and FM are different freq. range so will use a different tuner. They all use some of the same electronics but not all the same electronics.
You could check and make sure your antennae cable is securely plugged in, also make sure your outside antennae is still there, they have been known to break off.
If you find it is the radio you can find replacements fairly easy and they are not a whole lot of money for the most part. All Mygig radios are plug and play. If you have the stock RES radio you can upgrade to an RBZ touchscreen without problem. The one caveat would be that it must be a high speed can bus radio, Mygigs come in high speed and low speed canbus. You can check Ebay and other sites for Mygig radios.
Razzman
NorCal
2020 Limited CCSB
User on a Jeep forum had same issue, software was way out of date. Updated software and issue was gone. May or may not fix your issue but it won’t hurt to try.
V
vanila540i6
How do I do a update? Something I can do myself or dealer only?
V
vanila540i6
I have just the basic unit. No u connect or anything.
Cd. Am/fm aux and sat
