Dadio
Howdy,
I’ve a 2013, 1500, SLT 5.7 167,000 miles. Bought it new. Drive around 42000 a year no hauling, except ATV small trailer.
Have had all the maintenance done regularly, after a few larger repairs for exhaust manifold bolt issues both sides. * The #5 cylinder misfired, ok so you know the rest, the lifter rod is bad and destroyed the cam. I’m being told that this requires a new motor because the shavings from the cam have compromised the motor, does this sound like the real deal or is it a scam by the dealer. For some reason the mechanic I talked with who showed me the lifter rocker arm (value cover was off) not lifting, I believed. However, after looking over this great forum I’m having second thoughts if this is true.
Questions:
1. Motor replaced $9,000 (Long Block) 3 yr 150,000 Mile warranty
2. replace the cams and rods and take my chances Don’t know the cost
3. salvage the truck. No idea what it’s worth
*Dealer told me the metal bolts weren’t compatible with the aluminum block (sounds a little fishy) expanded and contracted at a different rate, that’s why they replaced with titanium bolts. I asked the dealer why was I having to pay for Mopar bad engineering, no answer.
Thanks for reading.
Questions:
Thanks for reading.
